Command 'juju enable-ha'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
Ensure that sufficient controllers exist to provide redundancy.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
-c, --controller Controller to operate in
--constraints Additional machine constraints
--format simple Specify output format (json|simple|yaml)
-n 0 Number of controllers to make available
-o, --output Specify an output file
--to The machine(s) to become controllers, bypasses constraints
Examples
Ensure that the controller is still in highly available mode. If there is only 1 controller running, this will ensure there are 3 running. If you have previously requested more than 3, then that number will be ensured.
juju enable-ha
Ensure that 5 controllers are available:
juju enable-ha -n 5
Ensure that 7 controllers are available, with newly created controller machines having at least 8GB RAM.
juju enable-ha -n 7 --constraints mem=8G
Ensure that 7 controllers are available, with machines server1 and server2 used first, and if necessary, newly created controller machines having at least 8GB RAM.
juju enable-ha -n 7 --to server1,server2 --constraints mem=8G
Details
To ensure availability of deployed applications, the Juju infrastructure must itself be highly available. The enable-ha command will ensure that the specified number of controller machines are used to make up the controller.
An odd number of controllers is required.
