The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
Generate the documentation for all commands
Usage
juju documentation [options] --out <target-folder> --no-index --split --url <base-url> --discourse-ids <filepath>
Options
Flag | Default | Usage |
--discourse-ids |
File containing a mapping of commands and their discourse ids | |
--no-index |
false | Do not generate the commands index |
--out |
Documentation output folder if not set the result is displayed using the standard output | |
--split |
false | Generate a separate Markdown file for each command |
--url |
Documentation host URL |
Examples
juju documentation
juju documentation --split
juju documentation --split --no-index --out /tmp/docs
To render markdown documentation using a list of existing commands, you can use a file with the following syntax
command1: id1
command2: id2
commandN: idN
For example:
add-cloud: 1183
add-secret: 1284
remove-cloud: 4344
Then, the urls will be populated using the ids indicated in the file above.
juju documentation --split --no-index --out /tmp/docs --discourse-ids /tmp/docs/myids
Details
This command generates a markdown formatted document with all the commands, their descriptions, arguments, and examples.
