The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: kill-controller, unregister
Destroys a controller.
Usage
juju destroy-controller [options] <controller name>
Options
Flag | Default | Usage |
-B , --no-browser-login |
--destroy-all-models |
false | Destroy all models in the controller |
--destroy-storage |
false | Destroy all storage instances managed by the controller |
--force |
false | Force destroy models ignoring any errors |
--model-timeout |
-1s | Timeout for each step of force model destruction |
--no-prompt |
false | Do not ask for confirmation |
--no-wait |
false | Rush through model destruction without waiting for each individual step to complete |
--release-storage |
false | Release all storage instances from management of the controller, without destroying them |
Examples
Destroy the controller and all models. If there is persistent storage remaining in any of the models, then this will prompt you to choose to either destroy or release the storage.
juju destroy-controller --destroy-all-models mycontroller
Destroy the controller and all models, destroying any remaining persistent storage.
juju destroy-controller --destroy-all-models --destroy-storage
Destroy the controller and all models, releasing any remaining persistent storage from Juju’s control.
juju destroy-controller --destroy-all-models --release-storage
Destroy the controller and all models, continuing even if there are operational errors.
juju destroy-controller --destroy-all-models --force
juju destroy-controller --destroy-all-models --force --no-wait
Details
All workload models running on the controller will first
need to be destroyed, either in advance, or by
specifying --destroy-all-models
If there is persistent storage in any of the models managed by the
controller, then you must choose to either destroy or release the
storage, using --destroy-storage
or --release-storage
respectively.
Sometimes, the destruction of a model may fail as Juju encounters errors that need to be dealt with before that model can be destroyed. However, at times, there is a need to destroy a controller ignoring such model errors. In these rare cases, use --force option but note that --force will also remove all units of any hosted applications, their subordinates and, potentially, machines without given them the opportunity to shutdown cleanly.
Model destruction is a multi-step process. Under normal circumstances, Juju will not proceed to the next step until the current step has finished. However, when using --force, users can also specify --no-wait to progress through steps without delay waiting for each step to complete.
WARNING: Passing --force with --model-timeout will continue the final destruction without consideration or respect for clean shutdown or resource cleanup. If model-timeout elapses with --force, you may have resources left behind that will require manual cleanup. If --force --model-timeout 0 is passed, the models are brutally removed with haste. It is recommended to use graceful destroy (without --force, --no-wait or –model-timeout).
