The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: add-credential
Sets the default region for a cloud.
Usage
juju default-region [options] <cloud name> [<region>]
Options
Flag | Default | Usage |
--reset |
false | Reset default region for the cloud |
Examples
juju default-region azure-china chinaeast
juju default-region azure-china --reset
Details
The default region is specified directly as an argument.
To unset previously set default region for a cloud, use --reset option.
To confirm what region is currently set to be default for a cloud, use the command without region argument.
