The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: resources, attach-resource
Display the resources for a charm in a repository.
Usage
juju charm-resources [options] <charm>
Options
Flag | Default | Usage |
-B , --no-browser-login |
--channel |
stable | the channel of the charm |
--format |
tabular | Specify output format (json|tabular|yaml) |
-m , --model |
-o , --output |
Specify an output file |
Examples
Display charm resources for the postgresql charm:
juju charm-resources postgresql
Display charm resources for mycharm in the 2.0/edge channel:
juju charm-resources mycharm --channel 2.0/edge
Details
This command will report the resources and the current revision of each resource for a charm in a repository.
Channel can be specified with --channel. If not provided, stable is used.
Where a channel is not supplied, stable is used.
