See also: disable-command, disabled-commands, enable-command
Enable destroy-controller by removing disabled commands in the controller.
Options
Flag | Default | Usage |
--B , --no-browser-login
--c , --controller
Controller to operate in |
Details
Any model in the controller that has disabled commands will block a controller from being destroyed.
A controller administrator is able to enable all the commands across all the models in a Juju controller so that the controller can be destoyed if desired.
