Locates and then downloads a CharmHub charm.
Usage
juju download [options] [options] <charm>
Options
| Flag | Default | Usage |
--arch |
all | specify an arch <all|amd64|arm64|armhf|i386|ppc64el|riscv64|s390x> |
--base |
specify a base | |
--channel |
specify a channel to use instead of the default release | |
--charmhub-url |
https://api.charmhub.io | specify the Charmhub URL for querying the store |
--filepath |
filepath location of the charm to download to | |
--no-progress |
false | disable the progress bar |
--series |
all | specify a series. DEPRECATED use --base |
Examples
juju download postgresql
juju download postgresql --no-progress - > postgresql.charm
Details
Download a charm to the current directory from the CharmHub store by a specified name. Downloading for a specific base can be done via –base. --base can be specified using the OS name and the version of the OS, separated by @. For example, --base ubuntu@22.04.
Adding a hyphen as the second argument allows the download to be piped to stdout.
