See also: download-backup
Create a backup.
Usage
juju create-backup [options] [<notes>]
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--filename |
juju-backup-<date>-<time>.tar.gz | Download to this file |
--m, --model |
--no-download |
false | Do not download the archive. DEPRECATED. |
Examples
juju create-backup
juju create-backup --no-download
Details
This command requests that Juju creates a backup of its state. You may provide a note to associate with the backup.
By default, the backup archive and associated metadata are downloaded.
Use --no-download to avoid getting a local copy of the backup downloaded at the end of the backup process. In this case it is recommended that the model config attribute “backup-dir” be set to point to a path where the backup archives should be stored long term. This could be a remotely mounted filesystem; the same path must exist on each controller if using HA.
Use --verbose to see extra information about backup.
To access remote backups stored on the controller, see ‘juju download-backup’.
