See also: set-constraints, model-constraints, set-model-constraints
Displays machine constraints for an application.
Usage
juju constraints [options] <application>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--format |
constraints | Specify output format (constraints|json|yaml) |
--m, --model |
--o, --output |
Specify an output file |
Examples
juju constraints mysql
juju constraints -m mymodel apache2
Details
Shows machine constraints that have been set for an application with juju set- constraints.
By default, the model is the current model.
Application constraints are combined with model constraints, set with juju set-model-constraints, for commands (such as ‘deploy’) that provision
machines for applications. Where model and application constraints overlap, the
application constraints take precedence.
Constraints for a specific model can be viewed with juju model- constraints.
