Command `charmcraft fetch-libs`
Usage:
charmcraft fetch-libs [options]
Summary:
Fetch charm libraries defined in charmcraft.yaml.
For each library in the top-level charm-libs key, fetch the latest library version matching those requirements.
For example: charm-libs: # Fetch lib with API version 0. # If fetch-libs is run and a newer minor version is available, # it will be fetched from the store. - lib: postgresql.postgres_client version: “0” # Always fetch precisely version 0.57. - lib: mysql.client version: “0.57”
Options:
-h, --help Show this help message and exit
-v, --verbose Show debug information and be more verbose
-q, --quiet Only show warnings and errors, not progress
--verbosity Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’
-V, --version Show the application version and exit
--format Produce the result in the specified format (currently only ‘json’)
See also:
  • create-lib
  • fetch-lib
  • list-lib
  • publish-lib
