Usage:
charmcraft build [options]
Summary:
Build a charm operator package.
You can juju deploy the resulting .charm file directly, or upload it
to Charmhub with charmcraft upload.
You must be inside a charm directory with a valid metadata.yaml,
requirements.txt including the ops package for the Python operator
framework, and an operator entrypoint, usually src/charm.py.
See charmcraft init to create a template charm directory structure.
Options:
-h, --help: Show this help message and exit
-v, --verbose: Show debug information and be more verbose
-q, --quiet: Only show warnings and errors, not progress
-t, --trace: Show all information needed to trace internal
behaviour
-p, --project-dir: Specify the project's directory (defaults to
current)
-f, --from: Charm directory with metadata.yaml where the
build takes place; defaults to '.'
-e, --entrypoint: The executable which is the operator entry
point; defaults to 'src/charm.py'
-r, --requirement: File(s) listing needed PyPI dependencies (can be
used multiple times); defaults to
'requirements.txt'
See also:
analyze
clean
init
pack
version
For a summary of all commands, run charmcraft help --all.
