Change bindings for a deployed application.
Usage
juju bind [options] <application> [<default-space>] [<endpoint-name>=<space> ...]
Options
| Flag | Default | Usage |
--B, --no-browser-login
--force |
false | Allow endpoints to be bound to spaces that might not be available to all existing units |
--m, --model
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID> |
Examples
To update the default binding for the application and automatically update all existing endpoint bindings that were referencing the old default, you can use the following syntax:
juju bind foo new-default
To bind individual endpoints to a space you can use the following syntax:
juju bind foo endpoint-1=space-1 endpoint-2=space-2
Finally, the above commands can be combined to update both the default space and individual endpoints in one go:
juju bind foo new-default endpoint-1=space-1
Details
In order to be able to bind any endpoint to a space, all machines where the application units are deployed to are required to be configured with an address in that space. However, you can use the --force option to bypass this check.
