See also: secret-backends, remove-secret-backend, show-secret-backend, update-secret-backend
Add a new secret backend to the controller.
Usage
juju add-secret-backend [options] <backend-name> <backend-type>
Options
| Flag | Default | Usage |
--c, --controller |
Controller to operate in | |
--config |
path to yaml-formatted configuration file | |
--import-id |
add the backend with the specified id |
Examples
juju add-secret-backend myvault vault --config /path/to/cfg.yaml
juju add-secret-backend myvault vault token-rotate=10m --config /path/to/cfg.yaml
juju add-secret-backend myvault vault endpoint=https://vault.io:8200 token=s.1wshwhw
Details
Adds a new secret backend for storing secret content.
You must specify a name for the backend and its type, followed by any necessary backend specific config values. Config may be specified as key values ot read from a file. Any key values override file content if both are specified.
To rotate the backend access credential/token (if specified), use the “token-rotate” config and supply a duration.
