See also: run, show-action
List actions defined for an application.
Usage
juju actions [options] <application>
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--format |
default | Specify output format (default|json|tabular|yaml) |
--m, --model |
--o, --output |
Specify an output file | |
--schema |
false | Display the full action schema |
Examples
juju actions postgresql
juju actions postgresql --format yaml
juju actions postgresql --schema
Details
List the actions available to run on the target application, with a short description. To show the full schema for the actions, use --schema.
