Cluster Migration via Restore
This is a How-To for restoring a backup that was made from the a different cluster, (i.e. cluster migration via restore). To perform a basic restore please reference the Restore How-To
Restoring a backup from a previous cluster to a current cluster requires that you:
When you restore a backup from an old cluster, it will restore the password from the previous cluster to your current cluster. Set the password of your current cluster to the previous cluster’s password:
juju run-action mongodb/leader set-password password=<previous cluster password> --wait
To view the available backups to restore you can enter the command list-backups:
juju run-action mongodb/leader list-backups --wait
This shows a list of the available backups (it is up to you to identify which backup-id corresponds to the previous-cluster):
    backups: |-
      backup-id             | backup-type  | backup-status
      YYYY-MM-DDTHH:MM:SSZ  | logical      | finished
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id to the command:
juju run-action mongodb/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ --wait
Your restore will then be in progress, once it is complete your cluster will represent the state of the previous cluster.
