Charmed MongoDB VM How-to | Minor upgrades
How to upgrade
The MongoDB charm supports minor version upgrades on both replica sets and sharded clusters.
This overview page contains:
Supported revisions
Below is a list of 6/stable revisions of Charmed MongoDB that support upgrades. If you wish to upgrade to/from a different revision, then perform a cluster migration via backup.
:warning: Only upgrade to or from these supported revisions in a production environment.
Before upgrading
Before upgrading, there are some important considerations to take into account:
Current state of your deployment
Before upgrading your Charmed MongoDB deployment, ensure that it is both active and idle with juju status. The deployment should be healthy and not performing and long running operations such as creating a backup.
Concurrency with other operations
We strongly recommend users to not perform any other extraordinary operations on Charmed MongoDB cluster while upgrading, as it can lead the cluster into inconsistent states.
Some examples of extraordinary are operations (but not limited to) the following:
  • Adding or removing units
  • Creating or destroying new relations
  • Upgrading other connected/related/integrated applications simultaneously
Backups
Make sure to have a backup of your data when running any type of upgrade. Guides on how to make a backup can be found here.
Next steps
Once you are ready to upgrade, proceed with:
  1. Revisions that support upgrades
  2. Perform a minor upgrade on a replica set
  3. Perform a minor upgrade on a sharded cluster
