After a fresh installation of modified the modified ha openstack-base bundle by
devzero openstack seams to be working fine all units are active and I am able to apply a custom theme with juju, create images and flavors with the openstack client and domains users and networks with horizon.
But after I create an instance I got a Bad Request (400) in horizon and in juju status I can see a Failed to connect to MySQL in openstack-dashboard and then Cluster is inaccessible from this instance for mysql-innodb-cluster and then more units start to get Failed to connect to MySQL
Active status is restored in all units after 30 minutes o so, and the created instance is running.
@pmatulis thas for the prompt reply.
I am attaching the log but the last line has a timestamp that does not correspond to the error that occurred about an hour ago, so I am not sure what is the problem
The resource I linked to shows a default of 600. The charm configuration option is max-connections but it corresponds to the upstream max_connections option. You will need to do some research and/or trial and error to determine what is appropriate for your environment.
