This started as a note-to-self for an integration testing development flow that I keep finding out and forgetting over and over again.
The typical integration testing module with pytest-operator looks something like:
# setup
@pytest.mark.abort_on_fail
async def test_build(ops_test): ...
async def test_deploy(ops_test): ...
async def test_integrate(ops_test): ...
# actual tests
async def test_1(ops_test): ...
async def test_2(ops_test): ...
# teardown
async def test_disintegrate(ops_test): ...
Note the three sections. The āpack - deploy - integrateā setup steps are, in all charms Iāve worked with so far, not very difficult to write. Most of the work is in iterating over the ābusiness logicā tests in the central section. In those tests you might want to, for example, run actions, read relation data, curl API endpoints, verify connectivity, test the workloads and so on.
However, a disproportionate amount of time is spent in the setup/teardown steps because of all the packing and waiting involved.
Wouldnāt it be nice if we could skip them, when weāre iterating on the tests?
It helps to think of the test functions in the module above as falling into one of two categories:
- tests that mutate the model topology (e.g. add or remove an app / unit / relation)
- tests that only observe and verify (e.g. run actions, send tcp requestsā¦)
Assuming you can keep the two nice and cleanly separated, you can do the following:
Using custom markers to (de)select topology-changing tests
Add a custom pytest mark to all of your topology-changing tests:
# in test_my_something_integration.py
# setup
@pytest.mark.setup # <<<
# business logic tests
# teardown
@pytest.mark.teardown # <<<
If you have whole modules or classes dedicated to performing setup/teardown tasks, you can also collectively mark those. See the documentation for how you can do that.
Now you can:
tox -e integration -- -k test_my_something_integration -m setup --keep-models
This will:
- set up your integration testing environment with tox, so you have all dependencies nicely encapsulated
- only run this test module
- only run the tests marked with
@pytest.mark.setup - keep the juju model that ops_test provisioned for you once the setup is done
When the command returns, assuming your charms pack/deploy/relate without issues, youāll have a test-something model in your currently selected juju controller.
Alternatively, you can create that manually, prior to running the setup tests, and pass the model name to ops-test using the --model flag. The command then becomes:
tox -e integration -- -k test_my_something_integration -m setup --model <some-model-name> --keep-models
In that model, youāll find your charms ready to be tested. Grab that model name, youāll need it next. Now comes the fun part. Run:
tox -e integration -- -k test_my_something_integration -m "not setup and not teardown" --model <some-model-name>
This will:
- select the juju model you already created (with all the charms/apps you already deployed and integrated)
- only run the tests not marked with either
setuporteardown, that is, only your business logic tests
The end
In conclusion, separating the test concerns allows you, by using a set of carefully selected pytest markers, to iterate quickly on parts of the testing suite (or the charm code that the suite is testing!).
Pro tip: say you have a failing integration test for an actual charm bug. For example, a config file isnāt where itās supposed to be. Thereās an issue with the charmās _push_config_to_container() function.
$ # prepare the testing env
$ tox -e integration -- -k my_test_module -m setup --keep-models
$ # switch to that model
$ juju switch test-model # name will be random
$ # go to the charm repo
$ cd /path/to/charm/repo
$ # set up code syncing
$ jhack sync -S mycharm
$ # fix your code
$ vim ./src/charm.py # do what needs doing
$ # once you save, `jhack sync` will push your changed charm.py file to the unit
$ # invoke the charm method that's pushing the config to the container
$ jhack eval myapp/0 "self._push_config_to_container()"
$ # run only the integration test that was failing
$ tox -e integration -- -k test_config_is_valid --model test-model
et voilĆ
