We’ll take a staged approach. Rather than try to charm everything and then try to wire each of the charms together, we’ll start with one large charm and slim it down over time.
Stage
Elements
Benefit
1 (basic install)
all systems are deployed onto a large instance
Binary artifacts are deployed as resources
few (if any) relations
Juju becomes easy to deploy behind the firewall
create Scalelite charm
create BBB bundle
horizontal scaling of BBB becomes trivial
1 (network)
Simplify deployment behind the firewall
charm Coturn
add support for http/etc relations
2 (database servers)
Increased performance because contention is reduced
The edgeyriders community seems interested in Jitsi. I might be able to convince that they help out here. But it would be a lower bar if it could go in nicely with Nextcloud…
Update: A friend of mine is working professionally with nextcloud. I asked if it would be possible to create an integration and he thought so. He had setup a few Jitsi services as well… Might get some help there.
Fantastic. I’ll create another thread for Jitsi. I created this one because I have been chatting to upstream. There’s the possibility for some extra support.
