Hi,
This is a short article about our charm debugging experience on GitHub (to share with the team). Many tests are failing on GitHub for "unknown reason"© producing some traceback and forcing developers to invest hours in reproducing the issue locally (usually without luck).
Be aware of your possibilities:
you can enable debug RUNNERS and STEPS on GitHub using repo secret
ACTIONS_RUNNER_DEBUG=trueandACTIONS_STEP_DEBUG=true. -
you should enable units DEBUG for the test model
logging-configfor your tests, e.g.:
- name: Setup operator environment
uses: charmed-kubernetes/actions-operator@main
with:
provider: microk8s
bootstrap-options: "--model-default 'logging-config=<root>=INFO;unit=DEBUG' --agent-version 2.9.42"
Another option is to set it inside the unit test:
MODEL_CONFIG = {"logging-config": "<root>=INFO;unit=DEBUG"}
await ops_test.model.set_config(MODEL_CONFIG)
- you can SSH into the GitHub runner and trace the failure in place with “lhotari/action-upterm”:
- name: Setup upterm session
if: success() || failure()
uses: lhotari/action-upterm@v1
with:
limit-access-to-actor: true
limit-access-to-users: your-github-nick
It will give you SSH URI to connect:
SSH Session: ssh vCwVzfRGKw6gCZ9r2S9e:MWNlNmQ0OGEudm0udXB0ZXJtLmludGVybmFsOjIyMjI=@uptermd.upterm.dev
Simply SSH there using your GitHub SSH key and continue juju/charm/microk8s troubleshooting commonly.
HINTS:
make sure you are testing with “–keep-models” option to keep the model running on tests failure/successes!
make sure you set DEBUG level for charm:
logging-config=<root>=INFO;unit=DEBUG(before running the test(s)).NOTE: GH runner will be cleaned on SSH logout and on timeout (6 hours by default).
you can fetch logs locally using CLI tool:
gh run view RUN_ID --log(e.g. to upload in a ticket the entire log). ReplaceRUN_IDwith the ID from view logs URL, e.g.: ~https://github.com/canonical/your-repo/actions/runs/4548879168/jobs/8030561836 -
be aware of the default
charmed-kubernetes/actions-operatorbehavior--model-default automatically-retry-hooks=false. Ops will abort testing on the first (and possibly temporary) charm state “error”. While locally, it is ignored by default due toautomatically-retry-hooks=true.
Have fun with charming debug on GitHub!!!
