Enable Archival
Excerpt from Temporal’s documentation:
Archival is a feature that automatically backs up Event Histories and Visibility records from Temporal Cluster persistence to a custom blob store.
Workflow Execution Event Histories are backed up after the Retention Period is reached. Visibility records are backed up immediately after a Workflow Execution reaches a Closed status.
Archival enables Workflow Execution data to persist as long as needed, while not overwhelming the Cluster’s persistence store.
This feature is helpful for compliance and debugging. Temporal’s Archival feature is considered experimental and not subject to normal versioning and support policy.
The archival feature can be enabled for Charmed Temporal K8s by relating it with the Charmed S3 Integrator, which provides it with the necessary credentials it needs to store event histories in S3 storage.
Deploy S3 Integrator
To deploy Charmed S3 Integrator, you need to run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy s3-integrator
Wait until the application is ready - when it is ready,
juju status --relations will show:
temporal-model temporal-controller microk8s/localhost 3.1.5 unsupported 12:35:24+03:00
s3-integrator blocked 1 s3-integrator stable 13 10.152.183.171 no installing agent
postgresql-k8s 14.7 active 1 postgresql-k8s 14/stable 73 10.152.183.250 no Primary
temporal-admin-k8s active 1 temporal-admin-k8s stable 4 10.152.183.21 no
temporal-k8s active 1 temporal-k8s stable 9 10.152.183.191 no
s3-integrator/0* blocked idle 10.1.232.2 Missing parameters: ['access-key', 'secret-key']
postgresql-k8s/0* active idle 10.1.232.66 Primary
temporal-admin-k8s/0* active idle 10.1.232.71
temporal-k8s/0* active idle 10.1.232.64
postgresql-k8s:database openfga-k8s:database postgresql_client regular
postgresql-k8s:database temporal-k8s:db postgresql_client regular
postgresql-k8s:database temporal-k8s:visibility postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
s3-integrator:s3-integrator-peers s3-integrator:s3-integrator-peers s3-integrator-peers peer
temporal-admin-k8s:admin temporal-k8s:admin temporal regular
temporal-admin-k8s:peer temporal-admin-k8s:peer temporal-admin peer
temporal-k8s:peer temporal-k8s:peer temporal peer
Configure S3 Integrator and Relate to Temporal K8s
Archival can be configured on any S3-compatible storage. S3 access and configurations are managed with the Charmed S3 Integrator:
juju config s3-integrator \
endpoint="https://s3.us-west-2.amazonaws.com" \
bucket="test-bucket-1" \
path="/temporal-archival" \
region="us-west-2"
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key> secret-key=<secret-key> --wait 1m
juju relate temporal-k8s s3-integrator
s3-integrator active 1 s3-integrator stable 13 10.152.183.171 no
s3-integrator/0* active idle 10.1.232.2
s3-integrator:s3-credentials temporal-k8s:s3-parameters s3 regular
Note: Make sure to observe the the output of juju debug-log to ensure that
there are no errors when configuring the S3 bucket as the destination for
Temporal event histories archival.
Enable Namespace Archival
Once the S3 relation is set up, namespace archival can be enabled using Temporal CLI as follows:
temporal operator namespace update --namespace <namespace> --history_archival_state enabled
temporal operator namespace update --namespace <namespace> --visibility_archival_state enabled
