Integrate applications
Integrations, known as “relations” in Juju 2.9, are the easiest way to create a user for PostgreSQL in Charmed PostgreSQL VM.
Integrations automatically create a username, password, and database for the desired user/application. As mentioned earlier in 3. Deploy PostgreSQL > Access PostgreSQL, it is a better practice to connect to PostgreSQL via a specific user rather than the admin user.
In this section, you will integrate your Charmed PostgreSQL to another charmed application.
This is part of the Charmed PostgreSQL VM Tutorial.
Please refer to the Overview for more information.
Data Integrator Charm
Before relating to a charmed application, we must first deploy our charmed application. In this tutorial, we will relate to the Data Integrator Charm. This is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms (e.g. PostgreSQL, MySQL, MongoDB, Kafka, etc) with a consistent, opinionated and robust user experience.
In order to deploy the Data Integrator Charm, we can use the command juju deploy
we have learned above:
juju deploy data-integrator --config database-name=test-database
The expected output:
Located charm "data-integrator" in charm-hub, revision 11
Deploying "data-integrator" from charm-hub charm "data-integrator", revision 11 in channel stable on jammy
Checking the deployment progress using juju status
will show a blocked
state for the newly deployed charm:
tutorial overlord localhost/localhost 3.1.7 unsupported 10:22:13+01:00
data-integrator blocked 1 data-integrator stable 11 no Please relate the data-integrator with the desired product
postgresql active 2 postgresql 14/stable 281 no
data-integrator/0* blocked idle 3 10.89.49.179 Please relate the data-integrator with the desired product
postgresql/0* active idle 0 10.89.49.129
postgresql/1 active idle 1 10.89.49.197
0 started 10.89.49.129 juju-a8a31d-0 jammy Running
1 started 10.89.49.197 juju-a8a31d-1 jammy Running
3 started 10.89.49.179 juju-a8a31d-3 jammy Running
The blocked
state is expected due to not-yet established relation (integration) between applications.
Relate to PostgreSQL
Now that the Database Integrator Charm has been set up, we can relate it to PostgreSQL. This will automatically create a username, password, and database for the Database Integrator Charm.
Relate the two applications with:
juju integrate data-integrator postgresql
Wait for juju status --watch 1s
to show all applications/units as active
tutorial overlord localhost/localhost 3.1.7 unsupported 10:22:31+01:00
data-integrator active 1 data-integrator stable 11 no
data-integrator/0* active idle 3 10.89.49.179
postgresql/0* active idle 0 10.89.49.129 Primary
To retrieve information such as the username, password, and database, run the command
This should output something like:
unit-data-integrator-0:
UnitId: data-integrator/0
results:
ok: "True"
postgresql:
database: test-database
endpoints: 10.89.49.129:5432
password: 136bvw0s7FjJ6mxZ
read-only-endpoints: 10.89.49.197:5432
username: relation-3
version: "14.7"
status: completed
timing:
completed: 2023-03-20 09:22:50 +0000 UTC
enqueued: 2023-03-20 09:22:46 +0000 UTC
started: 2023-03-20 09:22:50 +0000 UTC
Note that your hostnames, usernames, and passwords will likely be different.
Access the related database
Use endpoints
, username
, password
from above to connect newly created database test-database
on the PostgreSQL server:
> psql --host=10.89.49.129 --username=relation-3 --password test-database
test-database=> \l
test-database | operator | UTF8 | C.UTF-8 | C.UTF-8 | =Tc/operator +
| | | | | operator=CTc/operator +
| | | | | "relation-3"=CTc/operator
The newly created database test-database
is also available on all other PostgreSQL cluster members:
> psql --host=10.89.49.197 --username=relation-3 --password --list
When you relate two applications, Charmed PostgreSQL automatically sets up a new user and database for you.
Note the database name we specified when we first deployed the data-integrator
charm: --config database-name=test-database
Remove the user
Removing the integration automatically removes the user that was created when the integration was created. Enter the following to remove the integration:
juju remove-relation postgresql data-integrator
Now try again to connect to the same PostgreSQL you just used in Access the related database:
> psql --host=10.89.49.129 --username=relation-3 --password --list
This will output an error message like the one shown below:
psql: error: connection to server at "10.89.49.129", port 5432 failed: FATAL: password authentication failed for user "relation-3"
This is because the user no longer exists, as expected. Remember, juju remove-relation postgresql data-integrator
also removes the user.
Data remains on the server at this stage.
If you want to create a user again, integrate the applications again:
Re-integrating generates a new user and password:
You can then connect to the database with these new credentials. From here you will see all of your data is still present in the database.
