Reference > Release Notes > All revisions > Revision 363
Revision 363
February 21, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed PostgreSQL operator for IAAS/VM has been published in the 14/stable channel ![]()
- [CORE] PostgreSQL upgrade 14.9 → 14.10. (DPE-3217)
- Note: It is advisable to REINDEX potentially-affected indexes after installing this update! (See PostgreSQL changelog)
- [CORE] Juju 3.1.7+ support (#2037120)
- [PLUGINS] pgVector extension/plugin (DPE-3159)
- [PLUGINS] New PostGIS plugin (#312)
- [PLUGINS] More new plugins - 50 in total
- [MONITORING] COS Awesome Alert rules (DPE-3160)
- [SECURITY] Updated TLS libraries for compatibility with new charms
- manual-tls-certificates
- self-signed-certificates
- Any charms compatible with tls_certificates_interface.v2.tls_certificates
- All functionality from previous revisions
Bugfixes
- DPE-3199 Stabilized internal Juju secrets management
- DPE-3258 Check system identifier in stanza (backups setup stabilization)
Canonical Data issues are now public on both Jira and GitHub platforms. GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
What is inside the charms
- Charmed PostgreSQL ships the latest PostgreSQL
14.10-0ubuntu0.22.04.1 - PostgreSQL cluster manager Patroni updated to
v.3.1.2 - Backup tools pgBackRest updated to
v.2.48 - The Prometheus postgres-exporter is
0.12.1-0ubuntu0.22.04.1~ppa1 - VM charms based on Charmed PostgreSQL SNAP (Ubuntu LTS 22.04 -
ubuntu:22.04-based) revision 96 - Principal charms supports the latest LTS series 22.04 only
- Subordinate charms support LTS 22.04 and 20.04 only
Technical notes
- Starting with this revision (336+), you can use
juju refreshto upgrade Charmed PostgreSQL - Use this operator together with modern Charmed PgBouncer operator
- Please check the previously posted restrictions
- Ensure the charm requirements met
Contact us
Charmed PostgreSQL is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
