Reference > Release Notes > All revisions > Revision 288
Revision 288
Thursday, April 20, 2023
Dear community,
We’d like to announce that Canonical’s newest Charmed PostgreSQL operator for IAAS/VM has been published in the 14/stable channel. ![]()
- Deploying on VM (tested with LXD, MAAS)
- Scaling up/down in one simple juju command
- HA using Patroni
- Full backups and restores are supported when using any S3-compatible storage
- TLS support (using “tls-certificates” operator)
- DB access outside of Juju using “data-integrator”
- Data import using standard tools e.g. “psql”.
- Documentation:
Inside the charms:
- Charmed PostgreSQL charm ships the latest PostgreSQL “14.7-0ubuntu0.22.04.1”
- VM charms based on our SNAP (Ubuntu LTS “22.04” - core22-based)
Technical notes
- The new PostgreSQL charm is also a juju interface-compatible replacement for legacy PostgreSQL charms (using legacy interface
pgsql, via endpointsdbanddb-admin). However, it is highly recommended to migrate to the modern interfacepostgresql_client(endpointdatabase).- Please contact us if you are considering migrating from other “legacy” charms not mentioned above.
- Charmed PostgreSQL follows SNAP track “14”.
- No “latest” track in use (no surprises in tracking “latest/stable”)!
- PostgreSQL charm provide legacy charm through “latest/stable”.
- You can find charm lifecycle flowchart diagrams here.
- Modern interfaces are well described in the Interfaces catalogue and implemented by
data-platform-libs. - Known limitation: PostgreSQL extensions are not yet supported.
