Troubleshooting
Warning: At the moment, there is no ability to pause an operator.
Make sure your activity will not interfere with the operator itself!
juju runreplacesjuju run-action --waitinjuju v.2.9juju integratereplacesjuju relateandjuju add-relationinjuju v.2.9
This page goes over some recommended tools and approaches to troubleshooting the charm.
This reference goes over how to troubleshoot this charm via:
Before anything, always run juju status to check the list of charm statuses and the recommended fixes. This alone may already solve your issue.
juju logs
Ensure you are familiar with Juju logs concepts and how to manage Juju logs.
Always check the Juju logs before troubleshooting further:
juju debug-log --replay --tail
Focus on ERRORS (normally there should be none):
juju debug-log --replay | grep -c ERROR
Consider enabling the DEBUG log level if you are troubleshooting unusual charm behaviour:
juju model-config 'logging-config=<root>=INFO;unit=DEBUG'
The Patroni/PostgreSQL logs are located in workload container:
> ls -la /var/log/postgresql/
-rw-r--r-- 1 postgres postgres 23863 Sep 15 13:10 patroni.log
-rw------- 1 postgres postgres 2215 Sep 15 12:57 postgresql.log
If backups are enabled, Pgbackrest logs can also be found in the workload container:
> ls -la /var/log/pgbackrest/
-rw-r----- 1 postgres postgres 2949 Sep 18 10:42 all-server.log
-rw-r----- 1 postgres postgres 3219 Sep 18 10:41 test3.patroni-postgresql-k8s-stanza-create.log
For more information about the workload container, see the Container postgresql (workload) section below) section below.
kubectl
Check the operator architecture first to become familiar with charm and workload containers. Make sure both containers are Running and Ready to continue troubleshooting inside the charm.
To describe the running pod, use the following command (where 0 is a Juju unit id). :
kubectl describe pod postgresql-k8s-0 -n <juju_model_name>
Containers:
charm:
Image: jujusolutions/charm-base:ubuntu-22.04
State: Running
Ready: True
Restart Count: 0
postgresql:
Image: registry.jujucharms.com/charm/kotcfrohea62xreenq1q75n1lyspke0qkurhk/postgresql-image@something
State: Running
Ready: True
Restart Count: 0
charm container
To enter the charm container, use:
juju ssh postgresql-k8s/0 bash
Here you can make sure pebble is running. The Pebble plan is:
root@postgresql-k8s-0:/var/lib/juju# /charm/bin/pebble services
Service Startup Current Since
container-agent enabled active today at 12:29 UTC
root@postgresql-k8s-0:/var/lib/juju# ps auxww
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 718264 10876 ? Ssl 12:29 0:00 /charm/bin/pebble run --http :38812 --verbose
root 15 0.6 0.1 778628 59148 ? Sl 12:29 0:03 /charm/bin/containeragent unit --data-dir /var/lib/juju --append-env PATH=$PATH:/charm/bin --show-log --charm-modified-version 0
If you have issues here, please contact us.
Additionally, feel free to improve this document!
postgresql workload container
To enter the workload container, use:
juju ssh --container postgresql postgresql-k8s/0 bash
You can check the list of running processes and Pebble plan:
root@postgresql-k8s-0:/# /charm/bin/pebble services
metrics_server enabled active today at 12:30 UTC
pgbackrest server disabled inactive -
postgresql enabled active today at 12:29 UTC
root@postgresql-k8s-0:/# ps auxww
root 1 0.0 0.0 718264 10916 ? Ssl 12:29 0:00 /charm/bin/pebble run --create-dirs --hold --http :38813 --verbose
postgres 14 0.1 0.1 565020 39412 ? Sl 12:29 0:01 python3 /usr/bin/patroni /var/lib/postgresql/data/patroni.yml
postgres 30 0.0 0.0 1082704 9076 ? Sl 12:30 0:00 /usr/bin/prometheus-postgres-exporter
postgres 48 0.0 0.0 215488 28912 ? S 12:30 0:00 /usr/lib/postgresql/14/bin/postgres -D /var/lib/postgresql/data/pgdata --config-file=/var/lib/postgresql/data/pgdata/postgresql.conf --listen_addresses=0.0.0.0 --port=5432 --cluster_name=patroni-postgresql-k8s --wal_level=logical --hot_standby=on --max_connections=100 --max_wal_senders=10 --max_prepared_transactions=0 --max_locks_per_transaction=64 --track_commit_timestamp=off --max_replication_slots=10 --max_worker_processes=8 --wal_log_hints=on
postgres 50 0.0 0.0 70080 7488 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: logger
postgres 52 0.0 0.0 215592 9136 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: checkpointer
postgres 53 0.0 0.0 215604 9632 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: background writer
postgres 54 0.0 0.0 215488 12208 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: walwriter
postgres 55 0.0 0.0 216052 10928 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: autovacuum launcher
postgres 56 0.0 0.0 215488 8420 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: archiver
postgres 57 0.0 0.0 70196 8384 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: stats collector
postgres 58 0.0 0.0 216032 10476 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: logical replication launcher
postgres 60 0.0 0.0 218060 21428 ? Ss 12:30 0:00 postgres: patroni-postgresql-k8s: operator postgres 127.0.0.1(59528) idle
The list of running Pebble services will depend on configured (enabled) COS integration and/or backup functionality. Pebble and its service postgresql must always be enabled and currently running (the Linux processes pebble, patroni and postgres).
To ssh into the PostgreSQL unit, check the charm users concept and request admin credentials. Make sure you have psql installed.
> juju run postgresql-k8s/leader get-password username=operator
password: 3wMQ1jzfuERvTEds
> > psql -h 127.0.0.1 -U operator -d postgres -W
> > Password for user operator: 3wMQ1jzfuERvTEds
> > postgres=# \l
> > postgres | operator | UTF8 | C | C.UTF-8 | operator=CTc/operator +
> > | | | | | backup=CTc/operator +
Continue troubleshooting your database/SQL related issues from here.
Warning: Do NOT manage users, credentials, databases, schema directly. This avoids a split brain situation with the operator and integrated applications.
It is NOT recommended to restart services directly as it might create a split brain situation with operator internal state. If you see the problem with a unit, consider scaling down and re-scaling up to recover the cluster state.
As a last resort, contact us if you cannot determine the source of your issue.
Also, feel free to improve this document!
Install extra software
We recommend you do not install any additional software. This may affect stability and produce anomalies that are hard to troubleshoot.
Sometimes, however, it is necessary to install some extra troubleshooting software.
Use the common approach:
root@postgresql-k8s-0:/# apt update && apt install less
Setting up less (590-1ubuntu0.22.04.1) ...
Always remove manually installed components at the end of troubleshooting. Keep the house clean!
