Charmed PostgreSQL K8s Reference | Revision 280/281
Reference > Release Notes > All revisions > Revision 280/281
Revision 280/281
June 28, 2024
Dear community,
Canonical’s newest Charmed PostgreSQL K8s operator has been published in the ‘14/stable’ channel :tada:
Due to the newly added support for arm64 architecture, the PostgreSQL charm now releases two revisions simultaneously:
  • Revision 281 is built for amd64
  • Revision 280 is built for for arm64
Otherwise, it can be done at deploy time with the --constraints flag:
juju deploy postgresql-k8s --constraints arch=<arch> --trust
Highlights
Enhancements
Bugfixes
Canonical Data issues are now public on both Jira and GitHub.
For a full list of all changes in this revision, see the GitHub Release.
Technical details
This section contains some technical details about the charm’s contents and dependencies. Make sure to also check the system requirements.
Packaging
This charm is based on the charmed-postgresql snap (pinned revision 113). It packages:
Libraries and interfaces
This charm revision imports the following libraries:
  • grafana_agent v0 for integration with Grafana
    • Implements cos_agent interface
  • rolling_ops v0 for rolling operations across units
    • Implements rolling_op interface
  • tempo_k8s v1, v2 for integration with Tempo charm
    • Implements tracing interface
  • tls_certificates_interface v2 for integration with TLS charms
    • Implements tls-certificates interface
See the /lib/charms directory on GitHub for more details about all supported libraries.
See the metadata.yaml file on GitHub for a full list of supported interfaces
Contact us
  • Raise software issues or feature requests on GitHub
  • Report security issues through Launchpad
  • Contact the Canonical Data Platform team through our Matrix channel.
