Integrate with a client application
This guide will show you how to integrate a client application with a cross-regional async setup using an example PostgreSQL K8s deployment with two servers: one in Rome and one in Lisbon.
- Juju
v.3.4.2+ - Make sure your machine(s) fulfill the system requirements
- See supported target/source model relationships.
- A cross-regional async replication setup
Configure database endpoints
To make your database available to a client application, you must first offer and consume database endpoints.
Offer database endpoints
Offer the database endpoint on each of the postgresql applications.
juju switch rome
juju offer db1:database db1database
juju switch lisbon
juju offer db2:database db2database
Consume endpoints on client app
It is good practice to use a separate model for the client application rather than using one of the database host models.
juju add-model app
juju switch app
juju consume rome.db1database
juju consume lisbon.db2database
Internal client
If the client application is another charm, deploy them and connect them with juju integrate.
juju switch app
juju deploy postgresql-test-app
juju deploy pgbouncer-k8s --trust --channel 1/stable
juju relate postgresql-test-app:first-database pgbouncer-k8s
juju relate pgbouncer-k8s db1database
External client
If the client application is external, they must be integrated via the data-integrator charm.
juju switch app
juju deploy data-integrator --config database-name=mydatabase
juju deploy pgbouncer-k8s pgbouncer-external --trust --channel 1/stable
juju relate data-integrator pgbouncer-external
juju relate pgbouncer-external db1database
