How to deploy on GKE
Google Kubernetes Engine (GKE) is a highly scalable and fully automated Kubernetes service. To access the GKE Web interface, go to console.cloud.google.com/compute.
This guide will walk you through setting up a cluster and deploying PostgreSQL K8s on GKE.
- Install GKE and Juju tooling
- Create a new GKE cluster
- Bootstrap Juju on GKE
- Deploy charms
- List clusters and clouds
- Clean up
Install juju, kubectl, and Google Cloud command-line tools using snap:
sudo snap install juju
sudo snap install kubectl --classic
sudo snap install google-cloud-cli --classic
Authenticate
Log in to a Google account with the command
gcloud auth login
This should open a page in your browser starting with https://accounts.google.com/o/oauth2/... where you can complete the login.
If successful, the command prompt will show:
You are now logged in as [<account>@gmail.com].
Configure project ID
Next, you must associate this installation with GCloud project using “Project ID” from resource-management:
gcloud config set project <PROJECT_ID>
Sample output:
Updated property [core/project].
Install additional gcloud CLI tool
As a last step, install the Debian package google-cloud-sdk-gke-gcloud-auth-plugin using this Google guide: Install the gcloud CLI.
This guide will use high-availability zone europe-west1 and compute engine type n1-standard-4 in command examples. Make sure to choose the zone and resources that best suit your use-case.
The following command will start three compute engines on Google Cloud and deploy a K8s cluster (you can imagine the compute engines as three physical servers in clouds):
gcloud container clusters create --zone europe-west1-c $USER-$RANDOM --cluster-version 1.25 --machine-type n1-standard-4 --num-nodes=3 --no-enable-autoupgrade
Next, assign your account as an admin of the newly created K8s cluster:
kubectl create clusterrolebinding cluster-admin-binding-$USER --clusterrole=cluster-admin --user=$(gcloud config get-value core/account)
Bootstrap a new juju controller on the new cluster by running the following commands:
Note: This known issue forces unSNAPed Juju usage to add-k8s credentials on Juju.
/snap/juju/current/bin/juju add-k8s gke-jun-9 --storage=standard --client
juju bootstrap gke-jun-9
juju add-model welcome-model
At this stage, Juju is ready to use GKE. Check the list of currently running K8s pods with:
kubectl get pods -n welcome-model
Deploy charms
The following commands deploy PostgreSQL K8s and PgBouncer K8s:
juju deploy postgresql-k8s --trust
juju deploy pgbouncer-k8s --trust
To track the status of the deployment, run
juju status --watch 1s
To list GKE clusters and juju clouds, run:
gcloud container clusters list
Sample output:
NAME LOCATION MASTER_VERSION MASTER_IP MACHINE_TYPE NODE_VERSION >NUM_NODES STATUS mykola-18187 europe-west1-c 1.25.9-gke.2300 31.210.22.127 n1-standard-4 1.25.9-gke.2300 3 >RUNNING taurus-7485 europe-west1-c 1.25.9-gke.2300 142.142.21.25 n1-standard-4 1.25.9-gke.2300 3 >RUNNING
Juju can handle multiple clouds simultaneously. To see a list of clouds with registered credentials on Juju, run:
juju clouds
Sample output:
Clouds available on the controller: Cloud Regions Default Type gke-jun-9 1 europe-west1 k8s Clouds available on the client: Cloud Regions Default Type Credentials Source Description gke-jun-9 1 europe-west1 k8s 1 local A Kubernetes Cluster localhost 1 localhost lxd 1 built-in LXD Container Hypervisor microk8s 0 k8s 1 built-in A local Kubernetes context
Clean up
Warning: Always clean GKE resources that are no longer necessary - they could be costly!
To clean GKE clusters and juju clouds, use:
juju destroy-controller gke-jun-9-europe-west1 --yes --destroy-all-models --destroy-storage --force
juju remove-cloud gke-jun-9
gcloud container clusters delete <cluster_name> --zone europe-west1-c
Revoke the GCloud user credentials:
gcloud auth revoke your_account@gmail.com
You should see a confirmation output:
Revoked credentials: - your_account@gmail.com
