Configure S3 for AWS
A Charmed PostgreSQL K8s backup can be stored on any S3-compatible storage. S3 access and configurations are managed with the s3-integrator charm.
This guide will teach you how to deploy and configure the s3-integrator charm for AWS S3, send the configurations to the Charmed PostgreSQL application, and update it. (To configure S3 for RadosGW, see this guide)
Configure s3-integrator
First, deploy and run the charm:
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key-here> secret-key=<secret-key-here>
Then, use juju config to add your configuration parameters. For example:
juju config s3-integrator \
endpoint="https://s3.us-west-2.amazonaws.com" \
bucket="postgresql-test-bucket-1" \
path="/postgresql-test" \
region="us-west-2"
There is now an experimental configuration option that sets up a retention time (in days) for backups stored in S3: experimental-delete-older-than-days. More info on this guide
The amazon S3 endpoint must be specified as s3.<region>.amazonaws.com within the first 24 hours of creating the bucket. For older buckets, the endpoint s3.amazonaws.com can be used.
See this post for more information.
Integrate with Charmed PostgreSQL
To pass these configurations to Charmed PostgreSQL, integrate the two applications:
juju integrate s3-integrator postgresql-k8s
You can create, list, and restore backups now:
juju run postgresql-k8s/leader list-backups
juju run postgresql-k8s/leader create-backup
juju run postgresql-k8s/leader restore backup-id=<backup-id-here>
You can also update your S3 configuration options after relating using:
juju config s3-integrator <option>=<value>
The s3-integrator charm accepts many configurations - enter whichever are necessary for your S3 storage.
