Removal of Async replication
WARNING: it is an internal article. Do NOT use it in production! Contact Canonical Data Platform team if you are interested in the topic.
Pre-requisits
Make sure both Rome
and Lisbon
Clusters are deployed using the Async Deployment manual!
Detach Cluster from Async Replication Setup
Note: It is important to switchover the
Primary
Cluster before detaching it from the Async Replication Setup!
Assuming the Lisbon
is a current Primary
and we want to detach Rome
(for removal or reuse):
juju remove-relation -m lisbon async-primary db2:async-replica
The command above will move cluster Rome
into the detached state blocked
keeping all the data in place.
Removing detached cluster
Remove no-longer necessary Cluster Rome
(and destroy storage if Rome data is no longer necessary):
juju remove-application -m rome db1 # --destroy-storage
New Cluster from detached Cluster
Convert Rome
to the new Cluster keeping the current data in use:
juju run -m rome db1/leader promote-cluster
