How to manage passwords
If you are using PostgreSQL 16 (channel 16/<any>), passwords are managed with Juju secrets.
See the section Passwords with PostgreSQL 16.
If you are using PostgreSQL 14 (channel 14/<any>), passwords are managed with Juju’s get-password and set-password actions.
See the section Passwords with PostgreSQL 14.
On PostgreSQL 16, the charm uses Juju secrets to manage passwords.
See also: Juju | How to manage secrets
Create a secret
To create a secret in Juju containing one or more user passwords:
juju add-secret <secret_name> <user_a>=<password_a> <user_b>=<password_b>
The command above will output a secret URI, which you’ll need for configuring system-users.
Admin users that were not included in the secret will use an automatically created password.
To grant the secret to the postgresql charm:
juju grant-secret <secret_name> postgresql
Configure system-users
To set the system-users config option to the secret URI:
juju config charm-app system-users=<secret_URI>
When the system-users config option is set, the charm will:
- Use the content of the secret specified by the
system-usersconfig option instead of the one generated. - Update the passwords of the internal
system-usersin its user database.
If the config option is not specified, the charm will automatically generate passwords for the internal system-users and store them in a secret.
To retrieve the password of an internal system-user, run the juju show-secret command with the respective secret URI.
Update a secret
To update an existing secret:
juju update-secret <secret_name> <user_a>=<new_password_a> <user_c>=<password_c>
In this example,
user_a’s password was updated frompassword_atonew_password_auser_c’s password was updated from an auto-generated password topassword_cuser_b’s password remains as it was when the secret was added, butuser_bis no longer part of the secret.
See also: Explanation > Users
Get password
To retrieve the operator’s password:
juju run postgresql/leader get-password
Set password
To change the operator’s password to a new, randomized password:
juju run postgresql/leader set-password
To set a manual password for the operator/admin user:
juju run postgresql/leader set-password password=<password>
To set a manual password for another user:
juju run postgresql/leader set-password username=<username> password=<password>
