How to enable TimescaleDB
Charmed PostgreSQL separates TimescaleDB editions for different CharmHub tracks:
- Charmed PostgreSQL 16 ships Timescale Community edition.
- Charmed PostgreSQL 14 ships Timescale Apache 2 edition.
Enable TimescaleDB
To enable TimescaleDB plugin/extension simply run:
juju config postgresql plugin_timescaledb_enable=true
The plugin has been enabled on all units once the config-change event finished and all units reports idle:
> juju status
postgresql/3* active executing 3 10.189.210.124 5432/tcp (config-changed) Primary
postgresql/5 active executing 5 10.189.210.166 5432/tcp (config-changed)
postgresql/6 active executing 6 10.189.210.150 5432/tcp (config-changed)
postgresql/3* active idle 3 10.189.210.124 5432/tcp Primary
postgresql/5 active idle 5 10.189.210.166 5432/tcp
postgresql/6 active idle 6 10.189.210.150 5432/tcp
Disable TimescaleDB
To disable it explicitly, simply run:
juju config postgresql plugin_timescaledb_enable=false
The plugin has been disabled on all units once the config-change event finished and all units reports idle (same example as above).
Note: the extension will NOT be disable when database objects uses/depends on plugin is being disabled (clean the database to disable the plugin):
> juju status
postgresql/3* blocked idle 3 10.189.210.124 5432/tcp Cannot disable plugins: Existing objects depend on it. See logs
Another option is to reset the manually enabled config option (as it is disabled by default):
juju config postgresql --reset plugin_timescaledb_enable
Test TimescaleDB status:
Prepare the user_defined_action procedure:
postgres=# CREATE OR REPLACE PROCEDURE user_defined_action(job_id int, config jsonb) LANGUAGE PLPGSQL AS
BEGIN
RAISE NOTICE 'Executing action % with config %', job_id, config;
END
Run the following commands to test your TimescaleDB on Charmed PostgreSQL 14:
postgres=# SELECT add_job('user_defined_action','1h');
ERROR: function "add_job" is not supported under the current "apache" license
HINT: Upgrade your license to 'timescale' to use this free community feature.
postgres=# CREATE TABLE test_timescaledb (time TIMESTAMPTZ NOT NULL); SELECT create_hypertable('test_timescaledb', 'time');
CREATE TABLE
create_hypertable
(1,public,test_timescaledb,t)
(1 row)
TimescaleDB status on Charmed PostgreSQL 16:
add_job
1000
(1 row)
CREATE TABLE
create_hypertable
(1 row)
