How to deploy on LXD
This guide assumes you have a running Juju and LXD environment.
For a detailed walkthrough of setting up an environment and deploying the charm on LXD, refer to the Tutorial.
- Canonical LXD 5.12+
- Fulfil the general system requirements
Bootstrap a juju controller and create a model if you haven’t already:
juju bootstrap localhost <controller name>
juju add-model <model name>
Deploy PostgreSQL:
juju deploy postgresql
See the
juju deploydocumentation for all available options at deploy time.See the Configurations tab for specific PostgreSQL parameters.
Sample output of juju status --watch 1s:
postgresql overlord localhost/localhost 2.9.42 unsupported 09:41:53+01:00
postgresql active 1 postgresql 14/stable 281 no
postgresql/0* active idle 0 10.89.49.129
0 started 10.89.49.129 juju-a8a31d-0 jammy Running
Note: If you expect having several concurrent connections frequently, it is highly recommended to deploy PgBouncer alongside PostgreSQL. For more information, read our explanation about Connection pooling.
