Roles
Note: check the separate Users explanations first.
There are several definitions of Roles in Charmed PostgreSQL:
- Predefined PostgreSQL roles
- Instance level DB/relation-specific roles
- LDAP-specific roles
- Extra user roles relation flag
Predefined PostgreSQL 16 Roles
test123=> SELECT * FROM pg_roles;
rolname | rolsuper | rolinherit | rolcreaterole | rolcreatedb | rolcanlogin | rolreplication | rolconnlimit | rolpassword | rolvaliduntil | rolbypassrls | rolconfig | oid
pg_database_owner | f | t | f | f | f | f | -1 | ******** | | f | | 6171
pg_read_all_data | f | t | f | f | f | f | -1 | ******** | | f | | 6181
pg_write_all_data | f | t | f | f | f | f | -1 | ******** | | f | | 6182
pg_monitor | f | t | f | f | f | f | -1 | ******** | | f | | 3373
pg_read_all_settings | f | t | f | f | f | f | -1 | ******** | | f | | 3374
pg_read_all_stats | f | t | f | f | f | f | -1 | ******** | | f | | 3375
pg_stat_scan_tables | f | t | f | f | f | f | -1 | ******** | | f | | 3377
pg_read_server_files | f | t | f | f | f | f | -1 | ******** | | f | | 4569
pg_write_server_files | f | t | f | f | f | f | -1 | ******** | | f | | 4570
pg_execute_server_program | f | t | f | f | f | f | -1 | ******** | | f | | 4571
pg_signal_backend | f | t | f | f | f | f | -1 | ******** | | f | | 4200
pg_checkpoint | f | t | f | f | f | f | -1 | ******** | | f | | 4544
pg_use_reserved_connections | f | t | f | f | f | f | -1 | ******** | | f | | 4550
pg_create_subscription | f | t | f | f | f | f | -1 | ******** | | f | | 6304
Charmed PostgreSQL 16 Roles
Charmed PostgreSQL 16 introduced the following instance level predefined roles:
- charmed_stats (inherit from pg_monitor)
- charmed_read (inherit from pg_read_all_data)
- charmed_dml (inherit from pg_write_all_data)
- charmed_backup (inherit from pg_checkpoint)
- charmed_dba (WIP)
- charmed_instance_admin (WIP)
charmed_stats | f | t | f | f | f | f | -1 | ******** | | f | | 16386
charmed_read | f | t | f | f | f | f | -1 | ******** | | f | | 16388
charmed_dml | f | t | f | f | f | f | -1 | ******** | | f | | 16390
charmed_backup | f | t | f | f | f | f | -1 | ******** | | f | | 16392
Charmed PostgreSQL 14 Roles
Charmed PostgreSQL 14 ships the minimal necessary roles logic: each application relation got a user with dedicated role matching the resources owner. It can be fine-tuned using extra-users-roles relation flag. In general the following roles available for track 14:
- Predefined PostgreSQL Roles
- Predefined Charmed PostgreSQL Roles
- Charmed PostgreSQL LDAP Roles (rev 600+)
Predefined PostgreSQL 14 Roles
postgres=# SELECT * FROM pg_roles;
Predefined Charmed PostgreSQL 14 Roles
operator | t | t | t | t | t | t | -1 | ******** | | t | | 10
replication | f | t | f | f | t | t | -1 | ******** | | f | | 16384
rewind | f | t | f | f | t | f | -1 | ******** | | f | | 16385
postgres | t | t | f | f | t | f | -1 | ******** | | f | | 16386
backup | t | t | f | f | t | f | -1 | ******** | | f | | 16387
monitoring | f | t | f | f | t | f | -1 | ******** | | f | | 16388
admin | f | t | f | f | f | f | -1 | ******** | | f | | 16389
Relation specific Roles
For each application/relation the dedicated user is been created (with matching role and all all resources ownership). The resources ownership is being updated on each re-relation for new users/roles regeneration. Example of simple application relation to PostgreSQL and creating table:
relation_id_12 | f | t | t | t | t | f | -1 | ******** | | f | | 16416
postgres=# SELECT * FROM pg_user;
usename | usesysid | usecreatedb | usesuper | userepl | usebypassrls | passwd | valuntil | useconfig
relation_id_12 | 16416 | t | f | f | f | ******** | |
mydb=# \d+
List of relations
Schema | Name | Type | Owner | ...
public | mytable | table | relation_id_12 | ...
When the same application is being related through PgBouncer, the extra users/roles created following the same logic as above:
relation-14 | t | t | f | f | t | f | -1 | ******** | | f | | 16403
pgbouncer_auth_relation_14 | t | t | f | f | t | f | -1 | ******** | | f | | 16410
relation_id_13 | f | t | t | t | t | f | -1 | ******** | | f | | 16417
relation-14 | 16403 | f | t | f | f | ******** | |
pgbouncer_auth_relation_14 | 16410 | f | t | f | f | ******** | |
relation_id_13 | 16417 | t | f | f | f | ******** | |
mydb=# \d+
List of relations
public | mytable | table | relation_id_13 | ...
In this case there several records created to:
relation_id_13- for relation between Application and PgBouncerrelation-14- for relation between PgBouncer and PostgreSQLpgbouncer_auth_relation_14- to authenticate end-users which connects PgBouncer
To map LDAP users to PostgreSQL users, the dedicated LDAP groups have to be created before hand using Data Integrator charm. The result of such mapping will be a new PostgreSQL Roles:
myrole | t | t | f | f | t | f | -1 | ******** | | f | | 16422
