Reference > Release Notes > All revisions > Revisions 278/279/281/281
July 30, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed PgBouncer operator has been published in the 1/stable channel
| AMD64 | ARM64 |
| 279 (focal) 278 (jammy) |
281 (focal) 280 (jammy) |
- No new features, bugfixes release only.
Bugfixes and improvements
- [DPE-4772] Scaled up client should join the DB only when the subordinate is ready in #274
- [DPE-4811] Run CI on 3.4.4 in #283
- [DPE-4816] Add jinja2 as a dependency in #276
- [MISC] Suppress alias creation error in #284
- Test and CI stabilization fixes
- Python dependencies updates
GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
Charmed PgBouncer ships the latest PgBouncer
1.21.0-0ubuntu0.22.04.1~ppa1 -
The Prometheus pgbouncer-exporter is “
0.7.0-0ubuntu0.22.04.1~ppa1” -
VM charms based on the Charmed PgBouncer snap revisions 3 (
amd64) and 4 (arm64).Note: This release of the PgBouncer charm uses the new
charmed-pgbouncersnap. In previous releases, it was based on thecharmed-postgresqlsnap. Upgrading will automatically switch the snaps. -
Subordinate charms support LTS
22.04(jammy) and20.04(focal) only
Technical notes
- Check PgBouncer’s system requirements
- Use this operator together with the Charmed PostgreSQL operator
Contact us
Charmed PgBouncer is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
