Charmed PgBouncer Reference | Revisions 254-257
Reference > Release Notes > All revisions > Revisions 254/255/256/257
Jul 16, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed PgBouncer operator has been published in the 1/stable channel :tada: :
AMD64 ARM64
255 (focal)
256 (jammy)
254 (focal)
257 (jammy)
Bugfixes and improvements
  • PR #227 - Fixed PGB permissions issue when dropping tables after re-relating
  • PR #254 - Fixed failure when collecting readonly dbs
  • PR #257 - Fixed desync issue with PGB reporting the endpoint and credential of the database before being able to serve.
  • PR #268 - Fixed upgrade bugs when switching charms
GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
  • Charmed PgBouncer ships the latest PgBouncer 1.21.0-0ubuntu0.22.04.1~ppa1
  • The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1
  • VM charms based on the Charmed PgBouncer snap revisions 3 (amd64) and 4 (arm64).
Note: This release of the PgBouncer charm uses the new charmed-pgbouncer snap. In previous releases, it was based on the charmed-postgresql snap.
Upgrading will automatically switch the snaps.
  • Subordinate charms support LTS 22.04(jammy) and 20.04(focal) only
Technical notes
Contact us
Charmed PgBouncer is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
  • Raise software issues or feature requests on GitHub
  • Report security issues through Launchpad
  • Contact the Canonical Data Platform team through our Matrix channel.
