Reference > Release Notes > All revisions > Revision 394/395/396/397
September 11, 2024
Dear community,
Canonical’s newest Charmed PgBouncer operator has been published in the 1/stable channel.
Due to the newly added support for arm64 architecture, the PgBouncer charm now releases multiple revisions simultaneously:
- Revision 396 is built for
amd64on Ubuntu 22.04 LTS - Revision 395 is built for
amd64on Ubuntu 20.04 LTS - Revision 397 is built for
arm64on Ubuntu 22.04 LTS - Revision 394 is built for
arm64on Ubuntu 20.04 LTS
Otherwise, it can be done at deploy time with the --constraints flag:
juju deploy pgbouncer --constraints arch=<arch>
Highlights
- Added HA cluster interface (PR #317) (DPE-4066)
- Added URI to relation data (improves UX) (PR #324) (DPE-4683)
- Add Unix socket access for principal charm (including strict SNAPs) (PR #337) (DPE-4683)
Bugfixes
- Use poetry package-mode=false (PR #308)
- Switched test app interface (PR #310)
- Bumped data_interface and tempo libs (PR #318)
- Removed no longer necessary locales dependency (PR #328)
- Moved scheduled tests (PR #297)
- Shortened integration test job name (PR #292)
Dependencies and automations
- Switched Jira issue sync from workflow to bot (PR #327)
- Updated canonical/charming-actions action to v2.6.2 (PR #286)
- Updated data-platform-workflows to v21.0.1 (PR #348)
- Updated dependency cryptography to v43 (PR #295)
- Updated dependency juju/juju to v2.9.50 (PR #303)
- Updated dependency juju/juju to v3.4.5 (PR #306)
- Updated dependency tenacity to v9 (PR #311)
- Updated charm libs (PR #304)
Technical details
This section contains some technical details about the charm’s contents and dependencies.
Requirements
See the system requirements page for more details about software and hardware prerequisites.
Packaging
This charm is based on the CharmedPgBouncer snap Revision 15/16 . It packages:
Libraries and interfaces
This charm revision imports the following libraries:
- grafana_agent
v0for integration with Grafana- Implements
cos_agentinterface
- Implements
- rolling_ops
v0for rolling operations across units- Implements
rolling_opinterface
- Implements
- tempo_k8s
v1,v2for integration with Tempo charm- Implements
tracinginterface
- Implements
- tls_certificates_interface
v2for integration with TLS charms- Implements
tls-certificatesinterface
- Implements
See the /lib/charms directory on GitHub for more details about all supported libraries.
See the metadata.yaml file on GitHub for a full list of supported interfaces.
