Reference > Release Notes > All revisions > Revision 268/269
Revision 268/269
September 11, 2024
Dear community,
Canonical’s newest Charmed PgBouncer K8s operator has been published in the 1/stable channel.
Due to the newly added support for arm64 architecture, the PgBouncer K8s charm now releases multiple revisions simultaneously:
- Revision 269 is built for
amd64on Ubuntu 22.04 LTS ( pgbouncer-image r85 ) - Revision 268 is built for
arm64on Ubuntu 22.04 LTS ( pgbouncer-image r85 )
Otherwise, it can be done at deploy time with the --constraints flag:
juju deploy pgbouncer-k8s --trust --constraints arch=<arch>
Highlights
- Lightweight deployments due to the new and tiny charmed-pgbouncer rock (PR #376)
- Added URI to relation data (PR #380)
Bugfixes
- Ported PVC error test workaround and nodeport fixes (PR #395) (DPE-5205)
- Switched Jira issue sync from workflow to bot (PR #377)
- Automatically update rock by renovate (PR #387)
Dependencies and automations
- Lock file maintenance (PR #399)
- Lock file maintenance Python dependencies (PR #409)
- Update canonical/charming-actions action to v2.6.3 (PR #403)
- Update data-platform-workflows to v21.0.1 (PR #398)
- Update dependency canonical/microk8s to v1.31 (PR #373)
- Update dependency cryptography to v43.0.1 [SECURITY] (PR #406)
- Update ghcr.io/canonical/charmed-pgbouncer:1.21-22.04_edge Docker digest to 005a551 (PR #390)
Technical details
This section contains some technical details about the charm’s contents and dependencies.
Requirements
See the system requirements for more details about Juju versions and other software and hardware prerequisites.
Packaging
This charm is based on the CharmedPgBouncer K8s rock image (CharmHub pgbouncer-image resource-revision 85). It packages:
See the /lib/charms directory on GitHub for more details about all supported libraries.
See the metadata.yaml file on GitHub for a full list of supported interfaces.
