Hello,
I have never been able to get charmed OpenStack fully working. I’m wondering if anyone preferably UK based could lend me a hand sometime and walk me through the hardware and software requirements for my cluster. I am moving from a hyper-converged VMware infrastructure
Hi Peter, I have available hardware for a small charmed OpenStack lab but could never get it to work. Could you look at my hardware setup maybe there is a problem with that?
That should really be enough hardware (tight but doable). Where did you run into problems?
We are working to enable single-NIC configurations too, for simpler clouds.
Lastly, while I’m a fan of Charmed OpenStack, if your OpenStack is for the edge or very small clusters, take a look at MicroStack. It’s still in beta, but it is a minimal OpenStack for edge environments that puts a standard config into a single package so you don’t have many moving parts, just a single package install.
