Hello guys,
I’m trying to deploy a charmed Openstack cloud but haven’t had success with it. The bundle I’m using to deploy openstack is this one
However, the OSD Ceph nodes and the compute nodes keep on failing with the message hook failed: “config-changed”
From what I can see from the logs, I has something to do with the repositories not being valid:
Nova compute logs
2022-09-21 17:46:01 WARNING unit.nova-compute/0.juju-log server.go:316 Package openstack-release has no installation candidate.
2022-09-21 17:46:02 INFO unit.nova-compute/0.juju-log server.go:316 Performing OpenStack upgrade to yoga.
2022-09-21 17:46:02 INFO unit.nova-compute/0.juju-log server.go:316 DEPRECATION WARNING: Function configure_installation_source is being removed on/around 2017-07 : use charmhelpers.fetch.add_source() instead.
2022-09-21 17:46:02 INFO unit.nova-compute/0.juju-log server.go:316 Installing [] with options: ['--option=Dpkg::Options::=--force-confold']
2022-09-21 17:46:06 WARNING unit.nova-compute/0.config-changed logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
2022-09-21 17:46:06 WARNING unit.nova-compute/0.config-changed logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
2022-09-21 17:46:06 INFO unit.nova-compute/0.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
2022-09-21 17:46:21 WARNING unit.nova-compute/0.config-changed logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
2022-09-21 17:46:21 WARNING unit.nova-compute/0.config-changed logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
2022-09-21 17:46:21 INFO unit.nova-compute/0.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
2022-09-21 17:46:33 WARNING unit.nova-compute/0.config-changed logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
2022-09-21 17:46:33 WARNING unit.nova-compute/0.config-changed logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
2022-09-21 17:46:33 INFO unit.nova-compute/0.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
2022-09-21 17:46:45 WARNING unit.nova-compute/0.config-changed logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
2022-09-21 17:46:45 WARNING unit.nova-compute/0.config-changed logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
Ceph OSD Logs
> 022-09-21 17:44:40 WARNING unit.ceph-osd/1.install logger.go:60 File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
> 2022-09-21 17:44:40 WARNING unit.ceph-osd/1.install logger.go:60 raise CalledProcessError(retcode, cmd)
> 2022-09-21 17:44:40 WARNING unit.ceph-osd/1.install logger.go:60 subprocess.CalledProcessError: Command '['apt-get', 'update']' returned non-zero exit status 100.
> 2022-09-21 17:44:40 ERROR juju.worker.uniter.operation runhook.go:140 hook "install" (via explicit, bespoke hook script) failed: exit status 1
> 2022-09-21 17:44:40 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
> 2022-09-21 17:47:31 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
> 2022-09-21 17:49:40 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
> 2022-09-21 17:49:41 INFO unit.ceph-osd/1.juju-log server.go:316 Installing [] with options: ['--option=Dpkg::Options::=--force-confold']
> 2022-09-21 17:49:45 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:49:45 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:49:45 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:49:59 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:49:59 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:49:59 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:50:13 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:50:13 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:50:13 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:50:25 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:50:25 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:50:25 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:50:38 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:50:38 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:50:38 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:50:50 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:50:50 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:50:50 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:51:02 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:51:02 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:51:02 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:51:15 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:51:15 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:51:15 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:51:28 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:51:28 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:51:28 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:51:40 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:51:40 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:51:40 INFO unit.ceph-osd/1.juju-log server.go:316 Couldn't acquire DPKG lock. Will retry in 10 seconds
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 E: Failed to fetch http://ubuntu-cloud.archive.canonical.com/ubuntu/dists/focal-updates/yoga/InRelease 403 Forbidden [IP: 172.16.55.91 8000]
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 E: The repository 'http://ubuntu-cloud.archive.canonical.com/ubuntu focal-updates/yoga InRelease' is not signed.
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 Traceback (most recent call last):
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/install.real", line 911, in <module>
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 hooks.execute(sys.argv)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/charmhelpers/core/hookenv.py", line 963, in execute
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 self._hooks[hook_name]()
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/charmhelpers/contrib/hardening/harden.py", line 90, in _harden_inner2
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 return f(*args, **kwargs)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/install.real", line 320, in install
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 apt_update(fatal=True)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/charmhelpers/fetch/ubuntu.py", line 400, in apt_update
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 _run_apt_command(cmd, fatal)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/charmhelpers/fetch/ubuntu.py", line 945, in _run_apt_command
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 _run_with_retries(
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/var/lib/juju/agents/unit-ceph-osd-1/charm/hooks/charmhelpers/fetch/ubuntu.py", line 922, in _run_with_retries
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 result = subprocess.check_call(cmd, env=env, **kwargs)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 raise CalledProcessError(retcode, cmd)
> 2022-09-21 17:51:53 WARNING unit.ceph-osd/1.install logger.go:60 subprocess.CalledProcessError: Command '['apt-get', 'update']' returned non-zero exit status 100.
> 2022-09-21 17:51:53 ERROR juju.worker.uniter.operation runhook.go:140 hook "install" (via explicit, bespoke hook script) failed: exit status 1
> 2022-09-21 17:51:53 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
I’m trying to use Focal 20.04 and Openstack Yoga with no luck. I’ve tried to use Jammy 22.04 but I get an error from a few charms saying that jammy is not supported (i.e. Barbican).
Do you have any ideas why I’m getting this error?
Thank you in advance.
