Our docs have moved to a new home! Canonical Identity documentation
Please update your bookmarks, and contact us if you have any questions.
OAuth2 Proxy K8s Operator
This is the Kubernetes Python Operator for the OAuth2 proxy.
Description
OAuth2 Proxy is a reverse proxy and static file server that authenticates users through providers like Google and GitHub, allowing validation by email, domain, or group.
This operator provides the OAuth2 proxy, and consists of Python scripts which wraps the versions distributed by OAuth2 proxy.
Usage
The OAuth2 Proxy charm can be used to enable authentication for charmed and
non-charmed applications, by providing the oauth2 configuration to the charm,
and setting the upstream config value to the name of your application’s k8s
service. For charmed applications, this is the name of the deployed application.
Enable TLS
To enable TLS connections, you must have a TLS certificate stored as a k8s
secret (default name is oauth2-proxy-tls”). The secret name can be configured
using the tls-secret-name config property in the charm. A self-signed
certificate for development purposes can be created as follows:
# Generate private key
openssl genrsa -out server.key 2048
# Generate a certificate signing request
openssl req -new -key server.key -out server.csr -subj "/CN=oauth2-proxy-k8s"
# Create self-signed certificate
openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt -extfile <(printf "subjectAltName=DNS:oauth2-proxy-k8s")
# Create a k8s secret
kubectl -n <model-name> create secret tls oauth2-proxy-tls --cert=server.crt --key=server.key
Deploy
To deploy Charmed OAuth2 Proxy, you need to run the following commands, which will enable ingress in your microk8s, fetch the charm from Charmhub and deploy it to your model:
# Deploy ingress controller.
sudo microk8s enable ingress:default-ssl-certificate=<model-name>/oauth2-proxy-tls
# Deploy charms
juju deploy oauth2-proxy-k8s --channel edge
juju deploy nginx-ingress-integrator --channel edge --revision 103 --trust
# Set the necessary config
juju config oauth2-proxy-k8s \
upstream=<requirer_application_name> \
client-id=<client_id> \
client-secret=<client_secret> \
cookie-secret=<cookie_secret>
# Relate the charms
juju relate oauth2-proxy-k8s nginx-ingress-integrator
Verify Ingress Resource
To verify the ingress resources were correctly created, you can run the following command:
kubectl describe ingress -n <model-name>
Connect Ingress
Once deployed and related, find the IP of the ingress controller by running the following command:
kubectl get pods -n ingress -o wide
You should see something similar to the following output:
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
nginx-ingress-microk8s-controller-mfmtx 1/1 Running 512 (3h15m ago) 145d 10.1.232.8 ubuntu <none> <none>
Take note of the ingress controller IP address and add the IP-to-hostname
mapping in your /etc/hosts file as follows:
sudo nano /etc/hosts
# Add the following entries
10.1.232.8 oauth2-proxy-k8s
By default, the hostname will be set to the application name oauth2-proxy-k8s.
You should now be able to access your application at this address.
Verifying
To verify that the setup is running correctly, run
juju status --relations --watch 2s and ensure that all pods are active and the
required integrations exist.
Contributing
This charm is still in active development. Please see the
Juju SDK docs for guidelines on enhancements to this
charm following best practice guidelines, and CONTRIBUTING.md for developer
guidance.
License
The Charmed OAuth2 Proxy K8s Operator is free software, distributed under the Apache Software License, version 2.0. See License for more details.
