Charmed MySQL tutorial
The Charmed MySQL Operator delivers automated operations management from day 0 to day 2 on the MySQL Community Edition relational database. It is an open source, end-to-end, production-ready data platform on top of Juju. As a first step this tutorial shows you how to get Charmed MySQL up and running, but the tutorial does not stop there. Through this tutorial you will learn a variety of operations, everything from adding replicas to advanced operations such as enabling Transcript Layer Security (TLS). In this tutorial we will walk through how to:
- Set up your environment using LXD and Juju.
- Deploy MySQL using a single command.
- Access the admin database directly.
- Add high availability with MySQL InnoDB Cluster, Group replication.
- Request and change the admin password.
- Automatically create MySQL users via Juju relations.
- Reconfigure TLS certificate in one command.
While this tutorial intends to guide and teach you as you deploy Charmed MySQL, it will be most beneficial if you already have a familiarity with:
- Basic terminal commands.
- MySQL concepts such as replication and users.
Minimum requirements
Before we start, make sure your machine meets the following requirements:
- Ubuntu 20.04 (Focal) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required snaps and charms.
Prepare LXD
The fastest, simplest way to get started with Charmed MySQL is to set up a local LXD cloud. LXD is a system container and virtual machine manager; Charmed MySQL will be run in one of these containers and managed by Juju. While this tutorial covers the basics of LXD, you can explore more LXD here. LXD comes pre-installed on Ubuntu 20.04. Verify that LXD is installed by entering the command which lxd into the command line, this will output:
/snap/bin/lxd
Although LXD is already installed, we need to run lxd init to perform post-installation tasks. For this tutorial the default parameters are preferred and the network bridge should be set to have no IPv6 addresses, since Juju does not support IPv6 addresses with LXD:
lxd init --auto
lxc network set lxdbr0 ipv6.address none
You can list all LXD containers by entering the command lxc list in to the command line. Although at this point in the tutorial none should exist and you’ll only see this as output:
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
Install and prepare Juju
Juju is an Operator Lifecycle Manager (OLM) for clouds, bare metal, LXD or Kubernetes. We will be using it to deploy and manage Charmed MySQL. As with LXD, Juju is installed from a snap package:
Juju already has a built-in knowledge of LXD and how it works, so there is no additional setup or configuration needed. A controller will be used to deploy and control Charmed MySQL. All we need to do is run the following command to bootstrap a Juju controller named ‘overlord’ to LXD. This bootstrapping processes can take several minutes depending on how provisioned (RAM, CPU, etc.) your machine is:
juju bootstrap localhost overlord
The Juju controller should exist within an LXD container. You can verify this by entering the command lxc list and you should see the following:
| juju-<id> | RUNNING | 10.105.164.235 (eth0) | | CONTAINER | 0 |
where <id> is a unique combination of numbers and letters such as 9d7e4e-0
The controller can work with different models; models host applications such as Charmed MySQL. Set up a specific model for Charmed MySQL named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by entering the command juju status into the command line. You should see the following:
tutorial overlord localhost/localhost 2.9.37 unsupported 23:20:53Z
Model "admin/tutorial" is empty.
Deploy Charmed MySQL
To deploy Charmed MySQL, all you need to do is run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy mysql --channel edge
Juju will now fetch Charmed MySQL and begin deploying it to the LXD cloud. This process can take several minutes depending on how provisioned (RAM, CPU,etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of Charmed MySQL and gathering information about the machines hosting Charmed MySQL. Some of the helpful information it displays include IP addresses, ports, state, etc. The command updates the status of Charmed MySQL every second and as the application starts you can watch the status and messages of Charmed MySQL change. Wait until the application is ready - when it is ready, juju status will show:
tutorial overlord localhost/localhost 2.9.38 unsupported 22:52:47+01:00
mysql 8.0.32-0ubun... active 1 mysql edge 95 no Unit is ready: Mode: RW
mysql/0* active idle 0 10.234.188.135 Unit is ready: Mode: RW
0 started 10.234.188.135 juju-ff9064-0 jammy Running
To exit the screen with juju status --watch 1s, enter Ctrl+c.
Access MySQL
! Disclaimer: this part of the tutorial accesses MySQL via the
rootuser. Do not directly interface with the root user in a production environment. In a production environment always create a separate user using Data Integrator and connect to MySQL with that user instead. Later in the section covering Relations we will cover how to access MySQL without the root user.
The first action most users take after installing MySQL is accessing MySQL. The easiest way to do this is via the MySQL Command-Line Client mysql. Connecting to the database requires that you know the values for host, username and password. To retrieve the necessary fields please run Charmed MySQL action get-password:
juju run-action mysql/leader get-password --wait
unit-mysql-0:
UnitId: mysql/0
results:
password: <password>
username: root
status: completed
timing:
completed: 2023-01-29 21:58:53 +0000 UTC
enqueued: 2023-01-29 21:58:52 +0000 UTC
started: 2023-01-29 21:58:53 +0000 UTC
The host’s IP address can be found with juju status (the unit hosting the MySQL application):
To access the units hosting Charmed MySQL use:
mysql -h 10.234.188.135 -uroot -p<password>
Note if at any point you’d like to leave the unit hosting Charmed MySQL, enter Ctrl+d or type exit*.
The another way to access MySQL server is to ssh into Juju machine:
juju ssh mysql/leader
Inside the Juju virtual machine the root user can access MySQL DB simply calling mysql:
Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.19.0-29-generic x86_64)
ubuntu@juju-ff9064-0:~$ sudo mysql -e "show databases"
| Database |
| information_schema |
| mysql |
| mysql_innodb_cluster_metadata |
| performance_schema |
| sys |
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 56
Server version: 8.0.32-0ubuntu0.22.04.2 (Ubuntu)
Copyright (c) 2000, 2023, Oracle and/or its affiliates.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql>
Note if at any point you’d like to leave the mysql client, enter Ctrl+d or type exit.
You can now interact with MySQL directly using any MySQL Queries. For example entering SELECT VERSION(), CURRENT_DATE; should output something like:
mysql> SELECT VERSION(), CURRENT_DATE;
| VERSION() | CURRENT_DATE |
| 8.0.32-0ubuntu0.22.04.2 | 2023-01-29 |
1 row in set (0.00 sec)
Feel free to test out any other MySQL queries. When you’re ready to leave the mysql shell you can just type exit. Once you’ve typed exit you will be back in the host of Charmed MySQL (mysql/0). Exit this host by once again typing exit. Now you will be in your original shell where you first started the tutorial; here you can interact with Juju and LXD.
Scale Charmed MySQL
Charmed MySQL operator uses MySQL InnoDB Cluster for scaling. Being built on MySQL Group Replication, provides features such as automatic membership management, fault tolerance, automatic failover, and so on. An InnoDB Cluster usually runs in a single-primary mode, with one primary instance (read-write) and multiple secondary instances (read-only). The future versions on Charmed MySQL will take advantage of a multi-primary mode, where all instances are primaries. Users can even change the topology of the cluster while InnoDB Cluster is online, to ensure the highest possible availability.
! Disclaimer: this tutorial hosts replicas all on the same machine, this should not be done in a production environment. To enable high availability in a production environment, replicas should be hosted on different servers to maintain isolation.
Add cluster members (replicas)
You can add two replicas to your deployed MySQL application with:
juju add-unit mysql -n 2
You can now watch the scaling process in live using: juju status --watch 1s. It usually takes several minutes for new cluster members to be added. You’ll know that all three nodes are in sync when juju status reports Workload=active and Agent=idle:
tutorial overlord localhost/localhost 2.9.38 unsupported 23:33:55+01:00
mysql 8.0.32-0ubun... active 3 mysql edge 95 no
mysql/1 active idle 1 10.234.188.214 Unit is ready: Mode: RO
mysql/2 active idle 2 10.234.188.6 Unit is ready: Mode: RO
1 started 10.234.188.214 juju-ff9064-1 jammy Running
2 started 10.234.188.6 juju-ff9064-2 jammy Running
Remove cluster members (replicas)
Removing a unit from the application, scales the replicas down. Before we scale down the replicas, list all the units with juju status, here you will see three units mysql/0, mysql/1, and mysql/2. Each of these units hosts a MySQL replica. To remove the replica hosted on the unit mysql/2 enter:
juju remove-unit mysql/2
You’ll know that the replica was successfully removed when juju status --watch 1s reports:
tutorial overlord localhost/localhost 2.9.38 unsupported 23:46:43+01:00
mysql 8.0.32-0ubun... active 2 mysql edge 95 no
Passwords
When we accessed MySQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password for the admin user.
Retrieve the root password
As previously mentioned, the root password can be retrieved by running the get-password action on the Charmed MySQL application:
unit-mysql-0:
UnitId: mysql/0
results:
username: root
status: completed
timing:
completed: 2023-01-29 22:48:44 +0000 UTC
enqueued: 2023-01-29 22:48:39 +0000 UTC
started: 2023-01-29 22:48:43 +0000 UTC
Rotate the root password
You can change the root password to a new random password by entering:
juju run-action mysql/leader set-password --wait
unit-mysql-0:
UnitId: mysql/0
results: {}
status: completed
timing:
completed: 2023-01-29 22:50:45 +0000 UTC
enqueued: 2023-01-29 22:50:42 +0000 UTC
started: 2023-01-29 22:50:44 +0000 UTC
Please notice the status: completed above which means the password has been successfully updated. To be sure, please call get-password once again:
unit-mysql-0:
UnitId: mysql/0
results:
password: <new password>
username: root
status: completed
timing:
completed: 2023-01-29 22:50:50 +0000 UTC
enqueued: 2023-01-29 22:50:49 +0000 UTC
started: 2023-01-29 22:50:50 +0000 UTC
The root password should be different from the previous password.
Set the root password
You can change the root password to a specific password by entering:
juju run-action mysql/leader set-password password=my-password --wait && \
unit-mysql-0:
UnitId: mysql/0
results: {}
status: completed
timing:
completed: 2023-01-29 22:56:15 +0000 UTC
enqueued: 2023-01-29 22:56:11 +0000 UTC
started: 2023-01-29 22:56:14 +0000 UTC
unit-mysql-0:
UnitId: mysql/0
results:
password: my-password
username: root
status: completed
timing:
completed: 2023-01-29 22:56:16 +0000 UTC
enqueued: 2023-01-29 22:56:15 +0000 UTC
started: 2023-01-29 22:56:15 +0000 UTC
The root password should match whatever you passed in when you entered the command.
Integrations (Relations for Juju 2.9)
Relations, or what Juju 3.0+ documentation describes as Integration, are the easiest way to create a user for MySQL in Charmed MySQL. Relations automatically create a username, password, and database for the desired user/application. As mentioned earlier in the Access MySQL section it is a better practice to connect to MySQL via a specific user rather than the admin user.
Data Integrator Charm
Before relating to a charmed application, we must first deploy our charmed application. In this tutorial we will relate to the Data Integrator Charm. This is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms (e.g. MySQL, PostgreSQL, MongoDB, Kafka, etc) with a consistent, opinionated and robust user experience. In order to deploy the Data Integrator Charm we can use the comman juju deploy we have learned above:
juju deploy data-integrator --channel edge --config database-name=test-database
The expected output:
Located charm "data-integrator" in charm-hub, revision 3
Deploying "data-integrator" from charm-hub charm "data-integrator", revision 3 in channel edge on jammy
Checking the deployment progress using juju status will show you the blocked state for newly deployed charm:
tutorial overlord localhost/localhost 2.9.38 unsupported 00:07:00+01:00
data-integrator blocked 1 data-integrator edge 3 no Please relate the data-integrator with the desired product
data-integrator/1* blocked idle 4 10.234.188.85 Please relate the data-integrator with the desired product
4 started 10.234.188.85 juju-ff9064-4 jammy Running
The blocked state is expected due to not-yet established relation (integration) between applications.
Relate to MySQL
Now that the Database Integrator Charm has been set up, we can relate it to MySQL. This will automatically create a username, password, and database for the Database Integrator Charm. Relate the two applications with:
juju relate data-integrator mysql
Wait for juju status --watch 1s to show all applications/units as active:
tutorial overlord localhost/localhost 2.9.38 unsupported 00:10:27+01:00
data-integrator active 1 data-integrator edge 3 no
data-integrator/1* active idle 4 10.234.188.85
To retrieve information such as the username, password, and database. Enter:
juju run-action data-integrator/leader get-credentials --wait
This should output something like:
unit-data-integrator-1:
UnitId: data-integrator/1
results:
mysql:
endpoints: 10.234.188.135:3306
password: FbflReIypeRhDH4UZ90pbUvi
read-only-endpoints: 10.234.188.214:3306
username: relation-4
ok: "True"
status: completed
timing:
completed: 2023-01-29 23:11:17 +0000 UTC
enqueued: 2023-01-29 23:11:15 +0000 UTC
started: 2023-01-29 23:11:16 +0000 UTC
(Note: your hostnames, usernames, and passwords will likely be different.)
Access the related database
Use endpoints, username, password from above to connect newly created database test-database on MySQL server:
> mysql -h 10.234.188.135 -P 3306 -urelation-4 -pFbflReIypeRhDH4UZ90pbUvi -e "show databases"
| Database |
| test-database |
The newly created database test-database is also available on all other MySQL cluster members:
> mysql -h 10.234.188.214 -P 3306 -urelation-4 -pFbflReIypeRhDH4UZ90pbUvi -e "show databases"
| Database |
| test-database |
When you relate two applications Charmed MySQL automatically sets up a new user and database for you.
Please note the database name we specified when we first deployed the data-integrator charm: --config database-name=test-database.
Remove the user
To remove the user, remove the relation. Removing the relation automatically removes the user that was created when the relation was created. Enter the following to remove the relation:
juju remove-relation mysql data-integrator
Now try again to connect to the same MySQL you just used in Access the related database:
This will output an error message:
ERROR 1045 (28000): Access denied for user 'relation-4'@'_gateway.lxd' (using password: YES)
As this user no longer exists. This is expected as juju remove-relation mysql data-integrator also removes the user.
Note: data stay remain on the server at this stage!
Relate the the two applications again if you wanted to recreate the user:
Re-relating generates a new user and password:
You can connect to the database with this new credentials. From here you will see all of your data is still present in the database.
TLS is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed MySQL. This means (re-)configuring TLS on Charmed MySQL is readily available and requires minimal effort on your end.
Again, relations come in handy here as TLS is enabled via relations; i.e. by relating Charmed MySQL to the TLS Certificates Charm. The TLS Certificates Charm centralises TLS certificate management in a consistent manner and handles providing, requesting, and renewing TLS certificates.
Configure TLS
Before enabling TLS on Charmed MySQL we must first deploy the tls-certificates-operator charm:
juju deploy tls-certificates-operator --channel=edge --config generate-self-signed-certificates="true" --config ca-common-name="Tutorial CA"
Wait until the tls-certificates-operator is up and active, use juju status --watch 1s to monitor the progress:
tutorial overlord localhost/localhost 2.9.38 unsupported 00:40:42+01:00
tls-certificates-operator active 1 tls-certificates-operator edge 20 no
tls-certificates-operator/1* active idle 6 10.234.188.19
6 started 10.234.188.19 juju-ff9064-6 focal Running
Note: this tutorial uses self-signed certificates; self-signed certificates should not be used in a production cluster.
To enable TLS on Charmed MySQL, relate the two applications:
juju relate mysql tls-certificates-operator
Add external TLS certificate
Like before, connect to the MySQL in one of described above ways and check the TLS certificate in use:
> mysql -h 10.234.188.135 -uroot -pmy-password -e "SELECT * FROM performance_schema.session_status WHERE VARIABLE_NAME IN ('Ssl_version','Ssl_cipher','Current_tls_cert'))"
| VARIABLE_NAME | VARIABLE_VALUE |
| Current_tls_cert | custom-server-cert.pem |
| Ssl_cipher | TLS_AES_256_GCM_SHA384 |
| Ssl_version | TLSv1.3 |
Check the TLS certificate issuer:
juju ssh mysql/leader sudo openssl x509 -noout -text -in /var/lib/mysql/custom-server-cert.pem | grep Issuer
The output should indicate CA configured during TLS operator deployment:
Issuer: C = US, CN = Tutorial CA
Congratulations! MySQL is now using TLS cetrificate generated by the external application tls-certificates-operator.
Remove external TLS certificate
To remove the external TLS and return to the locally generate one, unrelate applications:
juju remove-relation mysql tls-certificates-operator
> mysql -h 10.234.188.135 -uroot -pmy-password -e "SELECT * FROM performance_schema.session_status WHERE VARIABLE_NAME IN ('Ssl_version','Ssl_cipher','Current_tls_cert')"
| Current_tls_cert | server-cert.pem |
juju ssh mysql/leader sudo openssl x509 -noout -text -in /var/lib/mysql/server-cert.pem | grep Issuer
The output should be similar to:
Issuer: CN = MySQL_Server_8.0.32_Auto_Generated_CA_Certificate
The Charmed MySQL application returned to the certificate server-cert.pem created locally in a moment of the MySQL server installation.
Next Steps
In this tutorial we’ve successfully deployed MySQL, added/removed cluster memebers, added/removed users to/from the database, and even enabled and disabled TLS. You may now keep your Charmed MySQL deployment running and write to the database or remove it entirely using the steps in Remove Charmed MySQL and Juju. If you’re looking for what to do next you can:
- Run Charmed MySQL on Kubernetes.
- Check out our Charmed offerings of PostgreSQL and Kafka.
- Give us your feedback.
- Contribute to the code base
If you’re done using Charmed MySQL and Juju and would like to free up resources on your machine, you can remove Charmed MySQL and Juju. Warning: when you remove Charmed MySQL as shown below you will lose all the data in MySQL. Further, when you remove Juju as shown below you will lose access to any other applications you have hosted on Juju.
To remove Charmed MySQL and the model it is hosted on run the command:
juju destroy-model tutorial --destroy-storage --force
Next step is to remove the Juju controller. You can see all of the available controllers by entering juju controllers. To remove the controller enter:
juju destroy-controller overlord
Finally to remove Juju altogether, enter:
sudo snap remove juju --purge
License:
The Charmed MySQL Operator is distributed under the Apache Software License, version 2.0. It installs/operates/depends on MySQL Community Edition, which is licensed under the GPL License, version 2.
Trademark Notice
MySQL is a trademark or registered trademark of Oracle America, Inc. Other trademarks are property of their respective owners.
