Reference > Release Notes > All revisions > Revision 267/268/269
Revision 267/268/269 (dpe/candidate only)
Dear community,
Canonical’s newest Charmed MySQL Router operator has been published in the dpe/candidate channel.
Due to the newly added support for arm64 architecture, the MySQL Router charm now releases multiple revisions simultaneously:
- Revision 267 is built for
amd64on Ubuntu 22.04 LTS - Revision 268 is built for
amd64on Ubuntu 20.04 LTS - Revision 269 is built for
arm64on Ubuntu 22.04 LTS
Otherwise, it can be done at deploy time with the --constraints flag:
juju deploy mysql-router --constraints arch=<arch>
Highlights
- Updated MySQL Router to v8.0.39 (PR #172) (DPE-4573)
- Added support for hacluster (PR #177) (DPE-5249)
- Add Tracing support (PR #180) (DPE-5312)
- Added warnings to destructive actions (PR #188) (DPE-5711)
- Use ruff as a linter and formatter (PR #162) (DPE-3881)
Bugfixes
This release contains no new bugfixes but library/dependencies updates only:
Libraries, testing, and CI
- Run tests on juju 3.6 on a nightly schedule (PR #173) (DPE-4976)
- Update 3.6 nightly tests to run against 3.6/candidate instead of 3.6/beta (PR #187)
- Run juju 3.6 nightly tests against 3.6/stable (PR #189)
- Switch from tox build wrapper to charmcraft.yaml overrides (PR #178)
- Update canonical/charming-actions action to v2.6.3 (PR #155)
- Update codecov/codecov-action action to v5 (PR #186)
- Update data-platform-workflows to v21 (PR #168)
- Update data-platform-workflows to v21.0.1 (PR #174)
- Update data-platform-workflows to v23 (PR #181)
- Update dependency cryptography to v43 [SECURITY] (PR #176)
Requirements and compatibility
See the system requirements for more details about Juju versions and other software and hardware prerequisites.
See the /lib/charms directory on GitHub for details about charm libraries.
See the metadata.yaml file on GitHub for a full list of supported interfaces.
Packaging
This charm is based on the Charmed MySQL snap revision 121/122.
