Reference > Release Notes > All releases > Revision 154/155
Revision 154/155
September 2, 2024
Dear community,
Canonical’s newest Charmed MySQL Router K8s operator has been published in the 8.0/stable channel.
Due to the newly added support for arm64 architecture, the MySQL Router K8s charm now releases two revisions simultaneously:
- Revision 155 is built for
amd64( mysql-router-image r57 ) - Revision 154 is built for
arm64( mysql-router-image r57 )
To make sure you deploy for the right architecture, we recommend setting an architecture constraint for your entire Juju model.
Otherwise, you can specify the architecture at deploy time with the --constraints flag as follows:
juju deploy mysql-router-k8s --constraints arch=<arch> --trust
Highlights
Below is an overview of the major highlights, enhancements, and bugfixes in this revision. For a detailed list of all commits since the last stable release, see the GitHub release notes.
- Upgraded MySQL Router from
v8.0.36→v8.0.37(see Packaging) - Added support for ARM architecture
Bugfixes
- [DPE-4173] Stabilize exporter tests by using listen-port to avoid ephemeral ports in #277
- [DPE-3881] Use ruff as a linter and formatter in #292
- Use poetry package-mode=false in #296
- [DPE-4739] Avoid using time.sleep in rollback integration tests in #298
- [DPE-4817] Upgrade to use lok_push_api v1 and capture rotated log files in #283
- Update Python dependencies
Technical details
This section contains some technical details about the charm’s contents and dependencies.
- The K8s NodePort used to expose the DB service will change after every refresh which might lead to disconnections of clients sitting outside Juju. Check more details in DPE-5276.
Requirements
See the system requirements page for more details about software and hardware prerequisites.
Packaging
This charm is based on the charmed-mysql rock (CharmHub mysql-router-image resource-revision 57). It packages:
- mysql-router
v8.0.37 - mysql-shell
v8.0.37 - prometheus-mysqlrouter-exporter
v5.0.1
Libraries and interfaces
- mysql
v0- See the Libraries tab in MySQL VM for the API reference.
- grafana_agent
v0for integration with Grafana- Implements
cos_agentinterface
- Implements
- rolling_ops
v0for rolling operations across units- Implements
rolling_opinterface
- Implements
- tempo_k8s
v1,v2for integration with Tempo charm- Implements
tracinginterface
- Implements
- tls_certificates_interface
v2for integration with TLS charms- Implements
tls-certificatesinterface
- Implements
See the /lib/charms directory on GitHub for a full list of supported libraries.
See the Integrations tab for a full list of supported integrations/interfaces/endpoints
Contact us
Charmed MySQL K8s is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
