Supported plugins/extensions
The following list contains all plugins/extensions supported by Charmed MySQL in alphabetical order. The revision column indicates which charm revision introduced support for the extension.
If you need support for other extensions, feel free to reach out to us.
| Plugin/extension name | Revision |
| plugin-audit-enabled | 272+ |
