Reference > Release Notes > All releases > Revision 312/313
Revision 312/313
December 3, 2024
Dear community,
Canonical’s newest Charmed MySQL operator has been published in the 8.0/stable channel.
Due to the newly added support for arm64 architecture, the MySQL charm now releases two revisions simultaneously:
- Revision 313 is built for
amd64 - Revision 312 is built for
arm64
To make sure you deploy for the right architecture, we recommend setting an architecture constraint for your entire Juju model.
Otherwise, you can specify the architecture at deploy time with the --constraints flag as follows:
juju deploy mysql --constraints arch=<arch>
This release of Charmed MySQL requires Juju v.3.4.3 or 3.5.2+. See the Technical details section for more information.
Highlights
Below is an overview of the major highlights, enhancements, and bugfixes in this revision. For a detailed list of all commits since the last stable release, see the GitHub release notes.
- Upgraded MySQL from
v8.0.36→v8.0.39(see Packaging) (DPE-4573) - Added support or ARM64 architecture (PR #472)
- Added support for Audit plugin (PR #488) (DPE-4366)
Enhancements
- Added Awesome Prometheus Alert Rules (criticality) (PR #493) (DPE-2477)
- Add integration with COS Tempo HA (DPE-5312)
- New Terraform module (PR #540) (DPE-5627)
- Changed binlog retention period (one week by default) (PR #503) (DPE-4247)
- Added support for re-scanning cluster for unit rejoin after node drain (PR #462) (DPE-4118)
- Enable and use admin address/port for operator users (PR #516) (DPE-5178)
Bugfixes
- Add warnings to destructive actions by (PR #555) (DPE-5711)
- Fixed MySQL Group replication start logic during the juju refresh (PR #546) (DPE-5941)
- Removed passwords from outputs and tracebacks (PR #499) (DPE-4266)
- Fixed cluster metadata and instance state checks (PR #482) (DPE-4850)
- Ensure username uniqueness (PR #464) (DPE-4643)
- Set instance offline mode on restore (PR #478) (DPE-4699)
- Fixes for backup logging (PR #471) (DPE-4699)
- Fixed global-primary on endpoint (PR #467) (DPE-4658)
- Skip set unknown config keys (PR #532) (DPE-5628)
- Change key logs from debug->info (PR #527) (DPE-4910)
- Fixed timeout node count query (PR #528) (DPE-5582)
- Skip plugin install for not file found (PR #524) (DPE-5540)
- Skip tls reconfiguration on unit teardown (PR #522) (DPE-5493)
- Upgrade fix for admin-address enabled charm (PR #520) (DPE-5178)
- Bump cffi to version 1.16.0 (PR #549)
- Fixed use juju provided ip (PR #558) (DPE-6105)
- Fixed regression on MAAS deployment (PR #554) (DPE-6055)
- Add new VM reboot tests (PR #534) (DPE-5415)
- Fixed starting group replication while waiting for upgrade (PR #546) (DPE-5941)
- Update all dependencies to the latest versions.
Technical details
This section contains some technical details about the charm’s contents and dependencies.
Requirements and compatibility
This charm revision features the following changes in dependencies:
- (increased) MySQL version
v8.0.39
v.3.4.3or3.5.2+. See the guide How to upgrade Juju for a new database revision.
See the system requirements page for more details about software and hardware prerequisites.
Integration tests
Below are the charm integrations tested with this revision on different Juju environments and architectures:
- Juju
v2.9.49onamd64 - Juju
v3.4.4onamd64andarm64
Juju v2.9.49 on amd64:
| Software | Version | |
| tls-certificates-operator | rev 22, legacy/stable |
Juju v3.4.4 on amd64 and arm64:
| self-signed-certificates | rev 155, latest/stable |
All:
| lxd | 5.12/stable |
| landscape-client | rev69 |
| ubuntu-advantage | rev95 |
| s3-integrator | rev31 |
| mysql-test-app | 0.0.2 |
See the /lib/charms directory on GitHub for a full list of supported libraries.
See the Integrations tab for a full list of supported integrations/interfaces/endpoints.
Packaging
This charm is based on the charmed-mysql snap Revision 113/114. It packages:
- mysql-server-8.0: 8.0.39-0ubuntu0.22.04.1
- mysql-router
v8.0.39: 8.0.39-0ubuntu0.22.04.1 - mysql-shell
v8.0.38: 8.0.38+dfsg-0ubuntu0.22.04.1~ppa2 - prometheus-mysqld-exporter
v0.14.0: 0.14.0-0ubuntu0.22.04.1~ppa2 - prometheus-mysqlrouter-exporter
v5.0.1: 5.0.1-0ubuntu0.22.04.1~ppa1 - percona-xtrabackup
v8.0.35: 8.0.35-31-0ubuntu0.22.04.1~ppa3
Contact us
Charmed MySQL is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
