Charmed MySQL K8s Tutorial - Managing Units
Scale your Charmed MySQL
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Adding and Removing units
Charmed MySQL K8s operator uses MySQL InnoDB Cluster for scaling. Being built on MySQL Group Replication, provides features such as automatic membership management, fault tolerance, automatic failover, and so on. An InnoDB Cluster usually runs in a single-primary mode, with one primary instance (read-write) and multiple secondary instances (read-only). The future versions on Charmed MySQL K8s will take advantage of a multi-primary mode, where multiple instances are primaries. Users can even change the topology of the cluster while InnoDB Cluster is online, to ensure the highest possible availability.
! Disclaimer: this tutorial hosts replicas all on the same machine, this should not be done in a production environment. To enable high availability in a production environment, replicas should be hosted on different servers to maintain isolation.
Add cluster members (replicas)
You can add two replicas to your deployed MySQL application by scaling it to three units using:
juju scale-application mysql-k8s 3
You can now watch the scaling process in live using: juju status --watch 1s. It usually takes several minutes for new cluster members to be added. You’ll know that all three nodes are in sync when juju status reports Workload=active and Agent=idle:
tutorial  overlord    microk8s/localhost  2.9.38   unsupported  22:48:57+01:00
App        Version    Status  Scale  Charm      Channel     Rev  Address         Exposed  Message
mysql-k8s  8.0.31     active      3  mysql-k8s  8.0/stable  36   10.152.183.234  no
Unit          Workload  Agent  Address      Ports  Message
mysql-k8s/0*  active    idle   10.1.84.74          Unit is ready: Mode: RW
mysql-k8s/1   active    idle   10.1.84.127         Unit is ready: Mode: RO
mysql-k8s/2   active    idle   10.1.84.73          Unit is ready: Mode: RO
Remove cluster members (replicas)
Removing a unit from the application, scales the replicas down. Before we scale down the replicas, list all the units with juju status, here you will see three units mysql-k8s/0, mysql-k8s/1, and mysql-k8s/2. Each of these units hosts a MySQL replica. To scale the application down to two units, enter:
juju scale-application mysql-k8s 2
You’ll know that the replica was successfully removed when juju status --watch 1s reports:
Scaling limitations
Note: the maximum number of Charmed MySQL K8s units in a single Juju application is 9. It is a limitation of MySQL Group replication, read more about all limitations here.
