Reference > Release Notes > All releases > Revision 180/181
Revision 180/181
September 2, 2024
Dear community,
Canonical’s newest Charmed MySQL K8s operator has been published in the 8.0/stable channel.
Due to the newly added support for arm64 architecture, the MySQL K8s charm now releases two revisions simultaneously:
- Revision 180 is built for
amd64( mysql-image r113 ) - Revision 181 is built for
arm64( mysql-image r113 )
To make sure you deploy for the right architecture, we recommend setting an architecture constraint for your entire Juju model.
Otherwise, you can specify the architecture at deploy time with the --constraints flag as follows:
juju deploy mysql-k8s --constraints arch=<arch> --trust
This release of Charmed MySQL K8s requires Juju v.3.4.3 or 3.5.2+. See the Requirements and compatibility section for more information.
Highlights
Below is an overview of the major highlights, enhancements, and bugfixes in this revision. For a detailed list of all commits since the last stable release, see the GitHub release notes.
Enhancements
- Upgraded MySQL from
v8.0.36→v8.0.37(see Packaging) - Added support or ARM64 architecture (PR #448)
- Added support for Audit plugin (PR #474) (DPE-4970)
- Add first Awesome Alert Rules (PR #469) (DPE-2477)
- Added support for rescanning cluster for unit rejoin after node drain (PR #433) (DPE-4118)
- Changed binlog retention period (one week by default) (PR #478) (DPE-4247)
Bugfixes
- Removed passwords from outputs and tracebacks (PR #473) (DPE-4266)
- Fixed intermittent issue on AKS deployments (unknown/idle state) (PR #458) (DPE-4850)
- Strip passwords from command execute output and tracebacks (PR #473) (DPE-4266)
- Address drained units rejoining the cluster with a new PV (PR #433) (DPE-4118)
- Ensure username uniqueness (PR #439) (DPE-4643)
- Backup stabilization fixes (PR #444) (DPE-4699)
- Idempotent configure method (PR #451) (DPE-4800)
- Show global-primary on endpoint (PR #440) (DPE-4658)
- Fix metrics-endpoint created on scale up (PR #483)
Technical details
This section contains some technical details about the charm’s contents and dependencies.
This charm revision features the following changes in dependencies:
- (increased) MySQL version
v8.0.37
v.3.4.3or3.5.2+. See the guide How to upgrade Juju for a new database revision.
See the system requirements page for more details about software and hardware prerequisites.
Integration tests
Below are the charm integrations tested with this revision on different Juju environments and architectures:
- Juju
v2.9.50onamd64 - Juju
v3.4.5onamd64andarm64
Juju v2.9.50 on amd64:
| Software | Version | |
| tls-certificates-operator | rev 22, legacy/stable |
Juju v3.4.5 on amd64 and arm64:
| self-signed-certificates | rev 155, latest/stable |
All:
| microk8s | v1.28.12 |
| s3-integrator | rev31 |
| mysql-test-app | 0.0.2 |
| mongodb-k8s | rev36 |
| kafka-k8s | rev5 |
| osm-keystone | rev10 |
| osm-pol | rev337 |
| zookeeper | 10 |
See the /lib/charms directory on GitHub for a full list of supported libraries.
See the Integrations tab for a full list of supported integrations/interfaces/endpoints
Packaging
This charm is based on the charmed-mysql rock (CharmHub mysql-image resource-revision 113). It packages:
- mysql-server-8.0: 8.0.37-0ubuntu0.22.04.1
- mysql-router
v8.0.37: 8.0.37-0ubuntu0.22.04.1 - mysql-shell
v8.0.37: 8.0.37+dfsg-0ubuntu0.22.04.1~ppa3 - prometheus-mysqld-exporter
v0.14.0: 0.14.0-0ubuntu0.22.04.1~ppa2 - prometheus-mysqlrouter-exporter
v5.0.1: 5.0.1-0ubuntu0.22.04.1~ppa1 - percona-xtrabackup
v8.0.35: 8.0.35-31-0ubuntu0.22.04.1~ppa3
Contact us
Charmed MySQL K8s is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
