How to integrate with another application
Integrations (formerly “relations”) are connections between two applications with compatible endpoints. These connections simplify the creation and management of users, passwords, and other shared data.
This guide shows how to integrate Charmed MySQL K8s with both charmed and non-charmed applications.
For developer information about how to integrate your own charmed application with MySQL K8s, see Development > How to integrate with your charm.
- Integrate with a charmed application
- Integrate with a non-charmed application
- Rotate application passwords
Integrations with charmed applications are supported via the mysql_client interface, and the legacy mysql interface.
Modern mysql_client interface
To integrate with a charmed application that supports the mysql_client interface, run
juju integrate mysql-k8s <charm>
To remove the integration, run
juju remove-relation mysql-k8s <charm>
Legacy mysql interface
Note that this interface is deprecated. See more information in Explanation > Legacy charm.
To integrate via the legacy interface, run
juju integrate mysql-k8s:mysql <charm>
Extended permissions can be requested using mysql-root endpoint:
juju integrate mysql-k8s:mysql-root <charm>
To integrate with an application outside of Juju, you must use the data-integrator charm to create the required credentials and endpoints.
Deploy data-integrator:
juju deploy data-integrator --config database-name=<name>
Integrate with MySQL:
juju integrate data-integrator mysql-k8s
Use the get-credentials action to retrieve credentials from data-integrator:
Rotate applications password
To rotate the passwords of users created for related applications, the relation should be removed and related again. That process will generate a new user and password for the application.
juju remove-relation <charm> mysql-k8s
juju integrate <charm> mysql-k8s
Internal operator user
The operator user is used internally by the Charmed MySQL K8s application. The set-password action can be used to rotate its password.
To set a specific password for the operator user, run
juju run mysql-k8s/leader set-password password=<password>
To randomly generate a password for the operator user, run
