Migrate database data via mysqldump
This document describes database data migration only!
For information about integrating charms via juju interfaces, see How to integrate a database with my charm.
Do you need to migrate?
A database migration is only required if the output of the following command is NOT mysql:
# replace DB_CHARM with your legacy DB application name
DB_CHARM= < mariadb | percona-cluster | mysql-innodb-cluster >
juju show-application ${DB_CHARM} | yq '.[] | .charm'
No migration is necessary if the output above is mysql!
Still, this manual can be used to copy data between different installations of the same (modern) charm mysql. The backup/restore method is recommended for migrations between modern charms.
The list of MariaDB/MySQL legacy VM charms:
- MariaDB
- Percona Cluster
- MySQL Innodb Cluster
OSM MariaDB K8s(K8s flavour, use separate manual)
There is a minor difference in commands for each of the legacy charms, but the general logic is common:
- Deploy the modern charm nearby
- Request credentials from legacy charm
- Remove relation to legacy charm (to stop data changes)
- Perform legacy DB dump (using the credentials above)
- Upload the legacy charm dump into the modern charm
- Add relation to modern charm
- Validate results and remove legacy charm
Before the data migration check all limitations of the modern Charmed MySQL charm!
Please check your application compatibility with Charmed MySQL before migrating production data from legacy charm!
Always perform the migration in a test environment before performing it in production!
- Client machine with access to deployed legacy charm
- Juju version 2.9 or later (check the Juju tech details for the different Juju versions)
- Enough storage in the cluster to support backup/restore of the databases.
mysql-clienton client machine (install by runningsudo apt install mysql-client).
Most legacy database charms support old Ubuntu series only, while Juju 3.x does NOT support Ubuntu Bionic.
It is recommended to use the latest stable revision of the charm on Ubuntu Jammy and Juju 3.x
Obtain existing database credentials
To obtain credentials for existing databases execute the following commands for each database to be migrated. Use those credentials in migration steps.
# replace DB_APP with desired unit name
DB_APP= < mariadb/0 | percona-cluster/leader | mysql-innodb-cluster/1 >
# obtain username and password of existing legacy database from DB relation
# username is usually `root` and password is specified in `mysql` relation by 'root_password'
OLD_DB_RELATION_ID=$(juju show-unit ${DB_APP} | yq '.[] | .relation-info | select(.[].endpoint == "mysql") | .[0] | .relation-id')
OLD_DB_USER=root
OLD_DB_PASS=$(bash -c "juju run --unit ${DB_APP} 'relation-get -r ${OLD_DB_RELATION_ID} - ${DB_APP}' | grep root_password" | awk '{print $2}')
OLD_DB_IP=$(juju show-unit ${DB_APP} | yq '.[] | .address')
Deploy new MySQL databases and obtain credentials
Deploy new MySQL databases and obtain credentials for each new database by executing the following commands, once per database:
# deploy new MySQL database charm
juju deploy mysql --channel 8.0/stable -n 3
# obtain username and password of new MySQL database from MySQL charm
NEW_DB_USER=$(juju run mysql/leader get-password | yq '.username')
NEW_DB_PASS=$(juju run mysql/leader get-password | yq '.password')
NEW_DB_IP=$(juju show-unit mysql/0 | yq '.[] | .address')
Migrate database
Use the credentials and information obtained in previous steps to perform the database migration by executing the following commands:
# ensure that there are no new connections are made and that database is not altered
# remove relation between your_application charm and legacy charm
juju remove-relation <your_application> <mariadb | percona-cluster | mysql-innodb-cluster>
# connect to the legacy database to verify connection
mysql \
--host=${OLD_DB_IP} \
--user=${OLD_DB_USER} \
--password=${OLD_DB_PASS} \
-e "show databases"
# choose which databases to dump/migrate to the new charm (one by one!)
DB_NAME=< e.g. wordpress >
# create backup of each database file using `mysqldump` utility, username, password, and unit's IP address, obtained earlier
# The dump will be created that can be used to restore database
OLD_DB_DUMP="legacy-mysql-${DB_NAME}.sql"
mysqldump \
--column-statistics=0 \
--databases ${OLD_DB_NAME} \
> "${OLD_DB_DUMP}"
# connect to new DB using username, password, and unit's IP address and restore database from backup
mysql \
--host=${NEW_DB_IP} \
--user=${NEW_DB_USER} \
--password=${NEW_DB_PASS} \
< "${OLD_DB_DUMP}"
Integrate with modern charm
# integrate your application and new MySQL database charm (using database or mysql endpoint)
juju integrate <your_application> mysql:database
# if database endpoint (mysql_client interface) is not yet supported, use legacy mysql interface:
juju integrate <your_application> mysql:mysql
Verify database migration
Note: some variables will vary for legacy and modern charms, namely: ${NEW_DB_PASS} and ${NEW_DB_IP}. These must be adjusted for the correct database, accordingly.
# compare new MySQL database and compare it to the backup created earlier
NEW_DB_DUMP="new-mysql-${DB_NAME}.sql"
mysqldump \
--databases ${DB_NAME} \
> "${NEW_DB_DUMP}"
diff "${OLD_DB_DUMP}" "${NEW_DB_DUMP}"
The difference between two SQL backup files should be limited to server versions, IP addresses, timestamps and other non data related information. Example of difference:
< -- Host: 10.1.45.226 Database: katib
> -- Host: 10.1.46.40 Database: katib
5c5
< -- Server version 5.5.5-10.3.17-MariaDB-1:10.3.17+maria~bionic
> -- Server version 8.0.34-0ubuntu0.22.04.1
16a17,26
> SET @MYSQLDUMP_TEMP_LOG_BIN = @@SESSION.SQL_LOG_BIN;
> SET @@SESSION.SQL_LOG_BIN= 0;
> -- GTID state at the beginning of the backup
> SET @@GLOBAL.GTID_PURGED=/*!80000 '+'*/ '0d3210b9-587f-11ee-acf3-b26305f815ec:1-4,
> 34442d83-587f-11ee-84f5-b26305f815ec:1-85,
> 34444583-587f-11ee-84f5-b26305f815ec:1';
22c32
< CREATE DATABASE /*!32312 IF NOT EXISTS*/ `katib` /*!40100 DEFAULT CHARACTER SET latin1 */;
> CREATE DATABASE /*!32312 IF NOT EXISTS*/ `katib` /*!40100 DEFAULT CHARACTER SET latin1 */ /*!80016 DEFAULT ENCRYPTION='N' */;
34c44
< `id` int(11) NOT NULL,
> `id` int NOT NULL,
60c70
< `id` int(11) NOT NULL AUTO_INCREMENT,
> `id` int NOT NULL AUTO_INCREMENT,
75a86
> SET @@SESSION.SQL_LOG_BIN = @MYSQLDUMP_TEMP_LOG_BIN;
86c97
< -- Dump completed on 2023-09-21 17:05:54
> -- Dump completed on 2023-09-21 17:09:40
Remove old databases
Test your application and if you are happy with a data migration, do not forget to remove legacy charms to keep the house clean:
juju remove-application --destroy-storage < mariadb | percona-cluster | mysql-innodb-cluster >
Links
Database data migration is also possible using mydumper.
This manual based on Kubeflow DB migration guide.
